best tpi manifold and runners?
Old Jun 25, 2006 | 08:25 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
well i kno they dont make aftermarket plenums so i was just gonna port that but i dont kno what to choose for a manifold and runners theres alot of different brands out there which is the best. I want to keep the ltr tpi no superram or stealthram.
Old Jun 25, 2006 | 09:46 PM
icecold's Avatar
Car: 1990 formula
Engine: 350 tpi supercharged
Transmission: 700 r4
personally i think the arizona speed and marine runners and the tpis big mouth base are the best out of the box performers
pete
Old Jun 25, 2006 | 09:49 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
I've been saying the AS&M large tube and Bigmouth combo for YEARS now. I know there are a few old threads out there covering this.
Old Jun 26, 2006 | 08:11 AM
r_wells1's Avatar
Car: 89 IROC
Engine: vortec head/ZZ4 cam/TPIed 350+.040
Axle/Gears: 3:27
Guys, I've been researching for the right manifold runner combination same as greenbird. I'm currently used the edlebrock Vortec manifold with stock runners.
Would the ASM LTRs also be a good runner for this manifold?
Will the ASM LTR increase the plenum height?
I using a Edelbrock Tower brace and it only has about 1/2 inch clearance betweeen the brace and thottle body.
Old Jun 26, 2006 | 08:28 AM
HD4mula's Avatar
Any aftermarket LTR will work with any base. All follow stock height when installed.
Old Jun 26, 2006 | 11:49 AM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
edelbrock or accel manifold?
i was thinking about a tpis (edelbrock) manifold with slp runners since they can be siamesed. But i dont kno if i should pick the tpis manifold or the accel superram manifold which is better?
Old Jun 26, 2006 | 01:51 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
SLP runners and any manifold would be my best bet. Just make sure to port the hell out of the plenum to maximize those slp runners.
Old Jun 26, 2006 | 11:15 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
if you have the money for it.
Home
you would have to get their complete intake, base, throttle body, runners & plenem, but its way bigger than anything else out there as far as TPI goes.
Old Jun 28, 2006 | 06:33 AM
B Rhodes's Avatar
Car: 91 B4C
anyone have any results using that system?
Old Jun 28, 2006 | 07:37 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
I bought the Edelbrock Hi flow runners and the Hi flow Intake. Then I bought a ported plenum off Ebay. I like it alot. Plus it looks good.
Old Jun 28, 2006 | 07:43 AM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
wow, that FIRST TPI system looks interesting... anyone hereactually have one? anyone have any flow/hp numbers?
Old Jun 28, 2006 | 02:25 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
The Edlebrock runners are your best bet. They have bigger diameter primaries than SLP . They can be siamesed ( ASM can't ) and ported all to heck . Out of all the runners I have to say they have the most potential. As far as bases go ... the TPIS one is a cleaned up Edlebrock unit . Accelll ...not too sure about .
Old Jun 28, 2006 | 03:47 PM
Js92RS's Avatar
Car: '92 Camaro RS
Engine: 355 TPI
Transmission: Tremec T-56
Axle/Gears: 10 bolt/3.42
I have the Edelbrock Hi-Flo TPI Intake Manifold Base & AS&M LTRs.
Old Jun 28, 2006 | 03:51 PM
'Shifter's Avatar
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
Damn, I wish I'd seen that First Injection stuff before I put all mine toghether....
Old Jun 28, 2006 | 10:02 PM
DENN_SHAH's Avatar
Brisk, i believe someone on this site got 1 & did some minor port work on it for a NA 406 & said it pulls hard all the way to 6500 RPM. a search for FIRST inductions or FIRST intakes on the intake board may turn it up.
stalkier
Dec 6, 2015 11:25 PM
Hawkeye1980
Aug 31, 2015 07:09 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
