Surging idle
Old Jun 26, 2006 | 01:54 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Surging idle
Yesterday I replaced my EGR valve, which obviously means that I had to take the upper pluenum off to get to it. I put everything back on and now I got a bad vacuum leak that I can't find even spraying ether to race the idle. My car is an 87 and I connected the MAT sensor, FPR vacum line, brake booster and smog stuff all back up. Is there anything im missing? I have to play with the gas for a few revs until it will idle on its own. Could a bad runner-to-plenum seal be the culprit? I know small vacuum leaks can hurt, I just dont know where to look. I could only get 3or 4 of the 8 runner bolts to line up in the plenum, do you think that could cause it?
Also it is running in open loop and surging like crazy, could a vacuum leak cause that? I put the stock air filters back in because I think my k&ns need to be reoiled and it seems like that helped.
Old Jun 26, 2006 | 04:05 PM
frederzick's Avatar
Car: 1991 Camaro Z-28
Transmission: Automatic
Axle/Gears: 2.73:1
YOU MAY WANT TO LOOSEN THE LOWER RUNNER BOLTS, TO ALLOW YOU TO GET THE UPPER BOLTS STARTED AND THEN TIGHTEN EVERYTHING DOWN.
Old Jun 26, 2006 | 07:43 PM
Thanks, i should retighten them sometime today.
Bump.
junior419
Apr 7, 2025 11:35 AM
IROCThe5.7L
Sep 17, 2015 07:48 AM
banksGTA
Sep 13, 2015 11:56 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
