how do you clean fuel lines
Old Jun 27, 2006 | 05:26 PM
383toy's Avatar
Over the last few weeks I've had some problems with my fuel system. I have an inline pump and have had to clean/replace both my primary and secondary fuel filters three times. The primary filter is a cleanable Russel filter located between the tank and the pump, and the secondary filter is a stock Camaro filter located between the pump and the injectors. Typically, I would note the vehicle starting to studder on acceleration, giving me the impression that the motor is being deprived of fuel. Sure enough, when I remove the primary filter I note a bunch of crap on the screen. Each time I cleaned the primary filter, and replaced the secondary, the motor would run great. Yesterday I changed/cleaned the filters, but noted the same type of engine stumbling/hestitation on acceleration that is typical of a plugged filter, and now I'm thinking that the line is clogged.
My question is this - can I clean the line by simply disconnecting the pressure and return lines, and blowing air through the pressure line? I'm thinking that the air should blow straight through taking all the dirt and crap along with it, but I'm not sure if I will damage the fuel pressure regulator.
PS - I will be removing the fuel tank at the same time and having it flushed at a rad shop.
Old Oct 17, 2013 | 12:29 AM
JNRSingh's Avatar
Car: '91 Camaro Z28
Engine: 305 TPI Mildly Modified
Transmission: 700R4 Stock
Re: how do you clean fuel lines
Did you ever end up doing this? I was considering this....
Old Oct 17, 2013 | 10:54 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
I doubt you'll hear back. That post was one of his last.....
Old Oct 18, 2013 | 01:13 AM
JNRSingh's Avatar
Car: '91 Camaro Z28
Hmmm sorry to hear that...thanks for the heads up paulo57509
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
mdtoren
Aug 23, 2015 12:52 PM
AkDrifted
Aug 17, 2015 07:45 PM
