Trouble setting timing
Old Jun 27, 2006 | 09:54 PM
griceformula's Avatar
Car: 92 formula
Engine: L98 350
Axle/Gears: 3.73 10 bolt
I have a 92 Formula, it has a TPI 350. I recently installed a LT4 HotCam, headers, and grinded down the wall behind the throttle body in the Plunem. When I went to set the timing, it seems to me that the computer is trying to retard the timing. The indicator on the harmonic balancer is jumping around from 6 degrees BTDC to 10 degrees BTDC then back to 6 degrees. I followed the Chilton's book on setting timing for A TPI. I unhooked the wire by the AC and I have tried to "reset the computer". This is my first TPI car and I was wondering if anyone else has had this problem, if so any help would be appreciated. I have a race coming up on July 7 and would like to have this fixed by then.
Old Jun 27, 2006 | 10:54 PM
Vader's Avatar
If the EST bypass connector is disconnected and the timing is not steady, the distributor may have some wear. There may also be a problem with the driven gear engagement, but it's more likely a distributor bushing worn.
Old Jul 1, 2006 | 11:42 AM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
Misfire?
Old Jul 2, 2006 | 10:15 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Ditto on what Vader said.
He's kinda smart too :-)
Also, without doing tuning on it, it might not be possible to get the base timing set accurately at 6 degrees.
Just a word to the wise.
U actually have/need a lot of tuning to make that hotcam happy in a speed density setup. Once u get it setup, its a damned nice combo
later
Jeremy
specialized
Jun 18, 2022 09:26 AM
bryan623
Mar 22, 2021 06:43 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
backtothe80s
Sep 5, 2015 12:39 AM
