opinions on this combo
Car: '87 S10 Blazer & '91 RS
Engine: L98 & L03
Transmission: 700R4 & T5
Axle/Gears: 10 Bolt/3.73/3.42
350 with around 9.5:1 compression
XE268
Vortec heads, behive springs, ect. machined for added lift
Edelbrock manifold
now this is where i get a little off course. i wish to stay with the LTR. anyone that doesn't agree, please don't waste my time.
would i be better off using the ASM runners, or saimeesing the base like madmax did. i like that setup more, because it looks bone stock, but i guess with a vortec setup, that won't matter much.
this motor is for a street driven S10 Blazer, so the low end torque is key. i don't care much about power above 5000rpms because it will almost never see that. thanks for any input you guys can provide, Jim.
XE268
Edelbrock manifold
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
What are the specs on the 268 im too lazy too look them up(they should have been here if u wanted honest critiquing)
later
Jeremy
later
Jeremy
Car: 88 GTA "Cocaine"
Engine: 350 tpi
the stock setup was designed for a stock 305 and works well with a 305. you will see nice gains by replacing the runners and lower intake
it is expensive though!
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
AS&M runners with an aftermarket manifold. I assume those are iron Vortex style heads. If aluminum bump up the compression ratio.
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
