I need some help!
Old Jul 5, 2006 | 11:50 PM
fattony's Avatar
I need some help!
i was gonna sell this beast but decided it had to many issues you could say to pawn off on some one esle. I just found a wire loose on my MAS and reconected it, well after i did that i romped on the pedal and it would rev and cut out and rev and cut out but when i slowly pressed the pedal it had great accelertion. what would make this happen? the two books i have on my IROC do not have have enough schematics to tell me what is what. hook me up if you got the answer.
Old Jul 6, 2006 | 02:50 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
Well my 1st thought would be lack of fuel. Have you changed your fuel filter? Maybe get a fule pressure guage on it and test that out. Could be a puel pump also.
Remember: AIR, FUEL, & SPARK. Are you getting Air? Good fuel pressure? Good spark?
Also maybe your fuel injectors are dirty, Run some seafoam through it.
Old Jul 11, 2006 | 05:41 PM
fattony's Avatar
well come to find out it was the spark i had put in platnums a while back when i should have had copper core. the beast is running great again thank you for the help. now that i got that fixed i can work on the power booster and master cylinder cuz you gotta be able to stop before you can go fast.
