383 w/stk ecm mass air?
Old Jul 9, 2006 | 09:33 AM
Les Holt's Avatar
Car: 87 chevy 4x4
Engine: 383 Mass Air TPI
Axle/Gears: corparates w/4.10's
Just getting ready to put 383 in my truck. Question is, will I be safe firing the engine with the ecm stk? The engine is flat top piston, Ported 993 heads, ported stk base and runners, crane powermax roller 214/220 @.050. The tpi is already in the truck, ran the 350 that was stk with minor issues. Engine in truck is wounded and I figured the 383 would be a better choice for towing. Any help would help, I don't want to wound this new engine.
Les Holt
Old Jul 9, 2006 | 11:25 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
It will run.
I would not trust driving it any real amount until you get some real time scan info and a wideband to verify it.
MAF only accomodates so much and you've now increased cubes and changed the cam.
later
Jeremy
Old Jul 10, 2006 | 11:54 AM
Les Holt's Avatar
Car: 87 chevy 4x4
Where would you suggest I take it to? I do have intentions of getting into doing programing for an upcoming megasquirt project but have too many time constraints at the present time and I need this truck up and going. I live in west central Indiana, close enought to Indy, Lafayette, or Danville Ill to make the trip worth while for the tune.
Les Holt
Old Jul 10, 2006 | 12:21 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
When I bought my car, it had the stock chip, 383, your same cam, headers, afr heads, stock intake, and ran fine. Ran 13.7's @ 102 in that state.
Old Jul 10, 2006 | 12:40 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
It will start/run and probably drive ok, but I wouldnt get on the gas any. The stock MAF and ECM is easily overwhelmed by large displacement engines and the pulsewidth will go flat when the MAF maxes out.
chazman
Aug 28, 2018 03:25 PM
Thornburg
Aug 27, 2015 08:28 PM
Keith5
Aug 27, 2015 04:37 PM
chazman
Aug 22, 2015 02:01 PM
