bad fuel managment, why?
Old Jul 25, 2006 | 03:33 AM
purpleZ-28's Avatar
Car: 85 Z28, 88 GTA, 68 Cutlass S
Engine: 305TPI X2 ;), Chevy 250
Transmission: T5, 700R4, powerslide >:(
Axle/Gears: posi, and posi w/discs :D.
ok, so recently the Z has been running terrible. it just doesnt respond anymore. it runs great when its cold, but then once its warmed up, it just bogs.
i replaced the fuel filter, same deal. i also replaced the plugs and wires, and no luck there either.
so now im starting to wonder if it isnt my MAF? i dont know much about the sensors and electronics in our cars (i work on older cars, where sensors are non existant).
i also have heard that something like this might happen if the cat is plugged up, could that be right? can i just eliminate the cat if thats the trouble?
any and all help is much apreciated
Old Jul 25, 2006 | 09:18 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
I am betting on the CTS sensor . Once the car warms up , the ECM thinks it's a different temp ,so it makes it run rich . Any codes ?
Old Jul 26, 2006 | 01:40 AM
purpleZ-28's Avatar
no codes, nothing to check them with, and it wont make it to shchucks for the free testing either.
what is a CTS sensor anyhow? where is it and how much do they cost if thats the problem?
Old Jul 26, 2006 | 02:03 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
you can check theem with a paper clip . there is a great tech article here on how to do so.
I am still thinking CTS ( coolant temperature sensor)
Old Jul 26, 2006 | 04:30 PM
purpleZ-28's Avatar
with a paper clip? cool, i will look that up. thank you!
Glowsock
Jul 24, 2025 03:15 PM
evilstuie
Jan 9, 2020 08:29 PM
Fast355
Dec 2, 2016 06:33 PM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
