backfire inside of tpi manifold....need help
Old Jul 26, 2006 | 06:30 PM
stangStomper83's Avatar
Car: 89 formula and my late 86 iroc R.I.P girl
Engine: 89 firebird formula-305 tbi,86 iroc 305 tpi
Transmission: both 700r4
at part throttle, mostly from a standstill or rolling stop i will get what sound like a muffeled backfire. its a single pop that sounds like its coming from inside the intake manifold. valves are not out of sink and i backed the timing of a little too. that did not help. has any one else had this problem, and what can i do to fix it.
Old Jul 26, 2006 | 06:39 PM
zeppelin5000's Avatar
Car: 1991 GTA Trans Am
Engine: 355 TPI
Transmission: 700R-4
You backed the timing a little meaning retarded it? If i'm correct advancing it would help you out with that. Also, have you checked your wires? I was having this problem and all I needed was a tune up, mainly new wires. The old ones were splitting causing spark jumps. Check under your hood at night with the car running. Look at the wires and look for blue sparks. I'm pretty sure bad wires can cause a backfiring sound from the intake.
Old Jul 26, 2006 | 08:09 PM
joejoe's Avatar
Car: red one
Engine: on the floor
Transmission: next to engine
Axle/Gears: the ones that turn
Mine was doing that, and it ended up being one of the rocker arm studs was pushed up out of the head a little. (Not that unherd of with hight miles)
Red iroc-z 305
Sep 30, 2015 05:22 PM
dyeager535
Aug 28, 2015 08:10 AM
Thirdgen89GTA
Aug 20, 2015 12:11 PM
Sanjay
Aug 12, 2015 03:41 PM
