Injector Question
Old Jul 29, 2006 | 04:49 PM
mrws6speed's Avatar
Car: '02 WS6 Conv M6, 92 WS6 Conv. M6
Injector Question
Hey everyone. I have a leaking injector that is causing my '92 305 TPI to surge.
I'm going to replace the injectors, but it is much cheaper to buy aftermarket sets....they only one's I can find are 22# injectors (they came with 19# stock).
The engine is the stock 305 with 62K miles on it. The only engine mods are headers and exhuast.
Will using the 22# injectors on a stock motor be too much and cause it to run rich? or would they be a perfect match?
eBay Motors: Chevy CORVETTE TPI-Bosch Fuel Injectors - NEW (item 330012128809 end time Aug-02-06 15:57:22 PDT)
Also...do you have to use the GM rings when you use the Ford injectors?
Old Jul 29, 2006 | 04:51 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Use GM 0-rings.
Get Ford SVO/Motorsports 19# injectors and away you go.
dont use 22# unless changing injector constant in prom
later
Jeremy
Old Jul 29, 2006 | 05:03 PM
mrws6speed's Avatar
So would something like these work?
eBay Motors: 8 BOSCH 19 LB H.O. 5.0 4.6 MUSTANG INJECTORS YELLOW TOP (item 130010694942 end time Jul-31-06 21:59:52 PDT)
Does anyone have any other good sources to get new ones?
Does anyone know the GM Part# for the 0-rings?
MustangBeater20
Oct 29, 2022 09:20 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
ezobens
Aug 19, 2015 10:29 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
