maf power and burnoff relay questions
Old Aug 3, 2006 | 11:52 AM
silverbullet86's Avatar
Car: 86 trans am
Engine: 305 tpi
Axle/Gears: 3.27 9 bolt posi
I got a 86 tpi and the wires going into the relay connectors are pulled apart. I got 88 parts car with the new style connectors and relays. Can I put the new style connectors and relays on my 86. The wires all look the same and I was hoping I could just cut the old connectors off and splice the new style connectors to my harness.
Any suggestions?
Old Aug 3, 2006 | 12:28 PM
Vader's Avatar
You can retrofit the newer style connectors and relays, or repair what you already have. The contacts can be rejected from the connector body, cleaned and soldered, and retensioned so the contacts remain firmly in the connector body.
Whichever way you go, you'll have to completely clean then grease the connectors with dielectric grease to prevent corrosion and moisture infiltration.
Old Aug 3, 2006 | 12:53 PM
Car: 86 trans am
Engine: 305 tpi
Thanks for the advice!
Car: 86 trans am
Engine: 305 tpi
I'm going th put the new style on because the connectors are sealed and are made better.
Glowsock
Jul 24, 2025 03:15 PM
89GTAOz
May 16, 2020 09:31 AM
Caspar
Jun 19, 2016 11:19 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
