question regarding splicing o2 wiring....
Old Aug 10, 2006 | 02:04 AM
LVZ2881's Avatar
Car: 1988 IROC
Transmission: 5 speed
Axle/Gears: 3.08 Posi 10 Bolt w/ aluminum drums
the wire to my o2 sensor is broken and needs repair.
will it affect the performance of the o2 sensor if i splice new wire in with butt connectors, or should I solder it in. I have no experience or equipement to solder however.
I'm worried about creating too much resistence in the o2 wire and affecting the readings.
Old Aug 13, 2006 | 07:47 AM
Vader's Avatar
It may work acceptably for a while, but the connection will eventually degrade, along with the signal it carries. That will start to affect your fuel bills to the point where a soldering iron and heat shrink tubing will look cheap by comparison.
BlackTopKing
May 8, 2014 07:34 PM
Shawn1989
Jul 18, 2013 07:23 PM
