I think I broke my toe LOL
Old Aug 12, 2006 | 05:16 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Kicking myself in the head! How can I use LT1 injectors on a 91 305 TPI? I was thinking I could but now I realize that worked on the last one because it was mass air, this ones not...is there any easy out for this...what can I do...it`s running FAT to fat to drive...all this on a new motor too.
Old Aug 12, 2006 | 05:53 PM
johnnyboy's Avatar
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
i dunno, sell the injectors and buy the proper ones
Old Aug 12, 2006 | 10:18 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Drop your fuel pressure or buy a chip burner and put the correct injector constant in the program. They are The LT1 are 24#IIRC at the stock 43 psi. Yours were 19#. If you hit "limp mode" it will be way fat and will run like crap too if your ignition is not strong.
Advancing the timing a bit may help but is the wrong way to fix it.
Old Aug 12, 2006 | 10:25 PM
vwdave's Avatar
I need a set of LT1 injectors. I'll trade you a set of 22's straight up.
Old Aug 13, 2006 | 05:51 AM
Who can burn a chip around here?
Old Aug 13, 2006 | 07:54 AM
Demon355's Avatar
What if you're LT1 injectors are the 22lbs ones?
Pac J
May 17, 2020 10:44 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
wanext
Oct 6, 2015 12:18 AM
bjpotter
Oct 4, 2015 07:48 PM
sjorgens
Oct 1, 2015 07:54 PM
