Strange problem, with idle when warm
Old Aug 15, 2006 | 05:52 PM
91Z28's Avatar
Car: 91' Z28
Engine: 355-Supercharged
So here's my current quandry The car runs fine when i start it up, drives fine cold, it's a little rough in drive but i excpect that on a non stock motor. Sometimes i dont think i have enough vac to operate the brake assist, but thats another problem. Anyway after i warm it up (take it out for a 10 min drive, maybe less) it starts bucking and stalling, maybe hunting, it's hard to get it going from a standstill, acts like it's outta gas. (At idle im running 40 LBS with the vac unplugged to the FPR.) Now if i put it in park the idle returns fine and things seem okay. No codes, but i think my eprom writer may have turned that off (if it's possible) I had somone burn a chip for my mods, so i could get it to a tune shop. My Idle is set to about 800 rpms in drive, timing is set at a stock 6 degrees, too low ? Any ideas as to what i might look at, im trying to fix it enough to get to the car show this weekend if i can, id like to show it for once
***On a side note i may have some upset catalayic converters, i thought i heard them rattling the other day. I have the dual factory cats into a 3 inch, no muffler.....
Old Aug 24, 2006 | 09:23 AM
Vader's Avatar
With that many changes to the engine, you really need to get it on a dyno and have a real PROM burned for it. I'm guessing that not much else is going to even get it running close to an acceptable level.
Infested
May 22, 2018 11:56 PM
red90IROCls1
Aug 25, 2015 06:56 AM
db057
Aug 22, 2015 08:17 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
