1/4 mile time
Old Aug 17, 2006 | 01:24 PM
Iroc_man's Avatar
Car: 87 Iroc
Axle/Gears: stock posi
1/4 mile time
whats the typical 1/4 mile time for a stock 87 Iroc-z 305 TPI?
Old Aug 17, 2006 | 01:31 PM
jack harrison's Avatar
Car: 1987 pontiac trans-am
Engine: 350 tpi
Axle/Gears: 3;73 with eaton lsd
auto or manual? the differance is about 4 10ths!
Old Aug 17, 2006 | 01:39 PM
Iroc_man's Avatar
Car: 87 Iroc
its an auto, man
Old Aug 17, 2006 | 01:40 PM
Iroc_man's Avatar
Car: 87 Iroc
another thing, how much hp do you think you will get from electric cooling fans, and 2 K&N air filters?
Old Aug 17, 2006 | 01:41 PM
Iroc_man's Avatar
Car: 87 Iroc
another thing, how much hp do you think you will get from electric cooling fans and 2 K&N air filters?
Old Aug 17, 2006 | 01:42 PM
Engine: 350 tpi
ok bear with me but a manual will do it in 14.9 seconds at 95 mph. thats good for stock!! im trying to look through a book to look for an auto.
Old Aug 17, 2006 | 01:43 PM
Iroc_man's Avatar
Car: 87 Iroc
im guessing 15 or 15.1?
Old Aug 17, 2006 | 01:50 PM
Engine: 350 tpi
maybe. a 350 auto will do a 14.6 at 95 and thats with an extra 20 bhp, so low low low 15s would be a good guesstimate!! oh and k&ns will be good for roughly 15-20 bhp on a well tuned motor. well worth the money, makes a better sound too!
Old Aug 17, 2006 | 01:52 PM
Iroc_man's Avatar
Car: 87 Iroc
i know i just put them in my car lol, im also gonna get a shift kit and a 180 degree thermostat. that should help.
Old Aug 17, 2006 | 01:58 PM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
Axle/Gears: 9 BOLT/ 3.27 GEARS
Im guessin You have an auto trans and 2.73 gears. I've seen that combo run as quick as a very low 15 and as slow as a very low 16. It all depends on the drivelines age and condition, the cars weight, driver, and track condition. And I dont think You will gain much power with kn filters and an electric fan. Maybe 5 hp at the most if Your lucky.
Old Aug 17, 2006 | 02:00 PM
Iroc_man's Avatar
Car: 87 Iroc
theres no way that the K&N airfilters PLUS the electric cooling fans will only give me 5 HP. plus, the engine was rebuilt, so it only has about 70 miles on the engine.
also headers are about to go on. so much for "5 hp".
Old Aug 17, 2006 | 02:28 PM
A RUSSH's Avatar
Car: 90 IROC-Z
K&N's are usually good for about 2-3% hp more if you add an air box
Old Aug 17, 2006 | 02:46 PM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
Two pieces of air filter are barely gonna give You anything noticeable whether the engine was recently rebuilt or not. If anything, install them because they are of higher quality and more economical than the stock filters. Not because U think they add 20 horsepower. Because they wont! The electric fans might give You 2 or 3 horsepower by freeing up inertia load if Ur car has a belt driven fan. Headers on the other hand will give Ur 305 10-15 horses, Theres no fiction in that! But have fun putting them on!
Old Aug 17, 2006 | 03:07 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
haahaa, yeah headers are not fun with a TPI motor. Electric fans though.....didnt that come stock? My 87 Trans Am came with 2 electric fans.
Iroc_man's Avatar
Car: 87 Iroc
i recently bought a pair of headers for my 81 el camino 305, which was carbed, but i sold it, so would it fit on my 87 Iroc TPI 305? it looks like it would fit, they are long tube headers. or would they not work because of the heads?
Old Aug 17, 2006 | 03:10 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
I stuck with the shorties on mine. Thay way I could use the Y pipe. True Duels are hard to do on 3rd gen.
Old Aug 17, 2006 | 03:17 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
K&Ns will not give 20hp on a TPI car.
Your car is TPI so it already has electric fans so you gained no power there.
I can promise you that G-body (elcamino monte carlo etc) long tubes will not fit because the chassis is different, not because the heads are different.
Which cam does your car have? Most peanut cammed TPI 305 cars with an automatic trans only run mid to high 15s at best. with 3.23 gears, headers and cat back exhaust, and a cam my car went 14.8. see the sig for the rest.
Old Aug 17, 2006 | 03:50 PM
88BlackZ-51's Avatar
i highly doubt a stock 87 305 TPI with a 700R4 tranny will do the 1/4 in high 14's. they are a slug!
my guess would be 15.30's for a well running one with stock everything.
Old Aug 17, 2006 | 04:29 PM
freestylzz's Avatar
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
I'm very doubtfull a STOCK '87 auto can go sub 15's.
Add 1/3 sec or more for an auto car......
Old Aug 17, 2006 | 04:59 PM
I remember seeing a bone stock 1989 Iroc with L-98 350 running 14.65@96MPH at Cayuga. I was told back then that this car was a real strong runner for what its worth.
Old Aug 17, 2006 | 07:01 PM
Iroc_man's Avatar
Car: 87 Iroc
seems kinda funny, actually my car aint a slug, it actually beat an 85 Iroc with a 350 that was put in it.
Old Aug 17, 2006 | 07:15 PM
sorry dude, if its a stock 305 TPI A4, its a slug. i mean no harm!
Old Aug 17, 2006 | 08:02 PM
thirdgenlover's Avatar
Car: 87 trans am
Engine: 350 TPI bored .040 over
Transmission: modified 700r4
Axle/Gears: stock spline, 3.73 Eaton posi
i did have a 305 in my 87 t.a. ,700r4 tranny, and 2.73 gears. best i could get was a 16.2, now i have a 350, same tranny, same gears and it ran a best of 15.4,still with old 305 intake. I still have the 350 engine, added a shift kit and have 3.73 gears now, havent ran it yet to see. car weight over 4224 lbs.
Old Aug 17, 2006 | 08:29 PM
cadman277's Avatar
Car: 95 z28,86 iroc
Engine: 350 lt1,305 tpi
I am hoping after i FINISH MY 305 IN MY 86 IROC TO BE IN THE MIDDLE 14S to say the least.I had an 86 olds cutlass with a 350,a comp cams camshaft and headers and ran a 15.6 in the quarter{which sucks}.I hope to do better with may iroc.
Old Aug 18, 2006 | 03:14 AM
roachjuice's Avatar
Car: 86 Omni GLHT
Engine: 2.2 Turbo/Intercooled
Transmission: 5 speed
Axle/Gears: 3:85
air filters don't increase horsepower.... they increase air flow.... and i would say around a mid to high 15..... you can race me...... it's just a 305 with bolt ons... and a bigger bump stick.....
Old Aug 18, 2006 | 02:42 PM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
4,224 LBS.??!!! No wonder You ran a 15.4... You should remove the 8 100 lb weights from the hatch before You go race!
Old Aug 18, 2006 | 02:50 PM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
The 85 Iroc never originally came with a 350. Therefore, the 350 was probably carelessly tossed in, needed tuning, or maybe it needed a rebuild. Your car is a decent launcher with its peanut cam, but thats about it! I've been in many Auto 305 TPI cars and they are not fast! They are slugzzz!!!
Old Aug 18, 2006 | 06:20 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Not even close. Maybe a 15.8
You got it right. I raced a 1987 350 TPI and it couldn;t get under a 15.4 actually He was pissed at my 1989 305 5 speed all stock with 227'000 km's beating him with a slow 15.1@93
Old Aug 19, 2006 | 12:21 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
My lb9 ran a 15.4 with a spark plug wire hanging off of the plug(could see the tip of the plug). Even with the few mods my 305 has it isn't a very good contender. It has ALOT more bark than bite.
http://www.zerotactic.net/uploads/ka...eofthelb9s.WMV
Old Aug 19, 2006 | 08:03 PM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
this fighting is getting intense. i will admit it, my 305 felt pretty strong for what it was on the street, as soon as you take it to the track, its a whole different story.
Yes that is what it said on my door, 4224 lbs. that was with the 305
Trust me,,, the door doesn't tell You Your exact vehicle weight. 4,224 is the Gross Vehicle Weight Capacity,,, meaning the maximum estimated weight You should permit in Your car. Your car probably weighs somewhere between 3,400 and 3,600 lbs. depending on Your options.
Old Aug 19, 2006 | 09:56 PM
Car: 87 trans am
i just thought that was the weight, well i have a few weighing stations close to me, actually one is so close i can see it from my house. will have to go over and weigh it some time
Old Aug 20, 2006 | 05:42 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
wow I was actually going to write something logical on this post but forget it. Hopefully the mods get to this entire post and delete it maybe next time you guys can drop the tough guy act and just talk. BTW the GVW is NOT the weight of the actual vehicle it's the MAXIMUM weight your car is supposed to have in it plus its weight. Your car probably weighs 3400 pounds as stated. And the typical times for stock 305's is low 16's high 15's that was the question posed, not how fast your car was with mods.
Old Aug 20, 2006 | 01:05 PM
manifoldsrme's Avatar
Car: 1985 IROC / 1986 SC
Engine: 305 TPI / 2.8 MFI
Transmission: 700R4's
Axle/Gears: 3.27 Posi / 3.42 Open
Bone stock 1985 305 TPI IROC here. Went to LVD in NY twice this year. With an open 3.42 rear and bad traction I ran 15.20's. I have a 9 bolt with 3.27's ready to go in and with traction I expect to crack in the 14's if just barely. No arguing or BSing, I drove it 80 miles there and 80 miles home.
Old Aug 20, 2006 | 02:09 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
manifoldsrme, yes but your 85 has the good cam. 86 and later got the dreaded peanut cam. Your car ran about what it should for an 85. peanut cammed cars usually go about 15.6-15.7
Old Aug 20, 2006 | 03:21 PM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
The 85 cars are good runners for the auto 305's.
Old Aug 20, 2006 | 04:57 PM
To set the record straight. If it said 4224 lbs then the car weighs 3474lbs.
5 seats x 150lbs a person is 750lbs.
4224-750=3474lbs.
not2 bad actually.
Old Aug 20, 2006 | 10:45 PM
roachjuice's Avatar
Car: 86 Omni GLHT
Axle/Gears: 3:85
85 cars run pretty good..... mine does.....
Old Aug 21, 2006 | 09:47 AM
iroc4ever's Avatar
Car: 1989 Iroc-Z
Axle/Gears: 2.73 (for now)
I got a 15.4 with my stock 305. And you two kids should grow up a bit....what exactly are you gaining by arguing with a stranger on the internet???
Old Aug 22, 2006 | 09:40 PM
3rdgen92maro's Avatar
Car: 1995 Firebird Formula
Transmission: Th350/4k stall
Axle/Gears: 10 bolt with 3.42s
id say low 15's. my 91 z went 14.6@94, and my old rs with boltons went 15.5 @90
Old Aug 22, 2006 | 09:52 PM
Vader's Avatar
All non-releveant posts have been deleted. The original question was a valid one, and reasonable replies are still present. The thread is still open, and will remain that way as long as we follow the posting rules.
Let's all just point it straight down the track and keep it between the stripes for the rest of this run, please.
Old Aug 23, 2006 | 11:56 AM
Iroc_man's Avatar
Car: 87 Iroc
3rdgen, what boltons did u have?
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
evilstuie
Jan 9, 2020 08:29 PM
Andrew6.688
Dec 13, 2015 10:59 AM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
