noticing quite a bit of knock when datalogging..
Car: 1991 Z28
Engine: SBC
Ive been datalogging the car lately, just looking for anything out of the oridinary when i noticed my knock count was kind of high compared to that of my friend who has a 91 z l98. His knock count was around 5 after a good 15 minutes of driving where as mine is like 228 lol. The cars are two completely different cars though in all aspects, but still, i figure thats a bit high. Now i have a rebuilt motor, higher compression and what not. I was wondering if A. i should retard the timing alittle (im running 6 degrees base) and B. if i should be running a tad bit colder of a plug? or perhaps gap my plugs differently?..just trying to find the cause of this. I know when you up compression, you should run a bit colder of a plug (of coarse depending on the increase in compression). I am running 91 or 93 octane all the time as well. I have a 160 degree thermo, fans on all the time for the most part and the car runs around 190 degrees. "Tuned" by pcmforless. If you need any more info just ask..
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i bet your tune is off.... its probly addin alot of timing. you could try bumping timing down alittle to see what happens
try 4 degrees and see if that helps...
then try the plugs. how high is your compression over stock?
Car: 1991 Z28
Engine: SBC
not much...i want to say 10:1 i believe and yea i believe my tune is off too. I have the data log if anyone wants to take a look at it..
FormulasOnly
Sep 10, 2015 09:07 PM
