Fastest ET's with a TPI 305?
Old Dec 6, 2006 | 11:52 AM
  #51
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
I ran a 14.87 @ 90.95 mph on my original 305 (peanut cam) with a ported plenum, Hooker 2055 headers, cat-back exhaust, 2200 stall converter, 3.42 gears/posi, and burning my own chip. I didn't have an air pump or cat, but did have the A/C hooked up and running (not at the track of course).
Old Dec 6, 2006 | 12:00 PM
  #52
2fast91's's Avatar
Car: 91 camaro z28
Engine: 383 with all holley performance
Transmission: 700r4 built for race
Axle/Gears: 3.73 limited slip
i ran 13.80 with my 305 (headers,intake,spark pluhs cables,exhaust,-
and a brand new 3.45 gears.)
Old Dec 6, 2006 | 01:00 PM
  #53
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
15.1 @93 mph , with 227'000 km's on a hot day about 1000 ft above sea level. With MAJOR blow by. ( kicked off track for spewing oil out the dipstick) .
Forgot to add it was a 5 speed with 3.08 LSD
Old Dec 6, 2006 | 01:52 PM
  #54
Rich92 RS's Avatar
Car: 86 IROC-Z, 98 Z28
Engine: 370 LSx, LS1
Transmission: T56's
Axle/Gears: 3.73, 3.42
Wow. To me that time seems really good with just those mods. I guess i should get a set of 3.45's?
Heres my best time with the IROC.
86 Iroc-Z LB9 Auto.
Stock, except for K&N's, a flowmaster muffler, and 3in cutout
1/8th Mile
9.87 @ 70.09 MPH w/2.16 60'
Old Dec 6, 2006 | 04:22 PM
  #55
MARO-MAN's Avatar
Car: I've had 4 thrid gens!!
Engine: Someday again I will have another!!
Originally Posted by 89305formula
i ran a 13.94 at 98mph in my 89 305 tpi formula i have an slp cold air box mac headers no cat no a.i.r and a descreend maf its a 5spd with 3.45 gears ina 9 bolt
That's pretty fast. No porting, heads, or cam? What were you getting for 60' times? All stock suspension/drag radials? That 5pd and 3.45 gears must make the difference. -Nick.
Old Dec 6, 2006 | 04:29 PM
  #56
MattODoom's Avatar
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
I'm shooting for 12's.
Old Dec 6, 2006 | 04:33 PM
  #57
MARO-MAN's Avatar
Originally Posted by 3rdgenZ
14.7 @ (i think 93) bone stock.
and 14.2 with the 373s in the back.
So, 3.73's would make that much of a difference? What were you stock gears? -Nick.
Old Dec 6, 2006 | 05:03 PM
  #58
BigWhiteGTP's Avatar
Car: 1994 Trans Am
What was the headers and exhaust you had on the 305? When I get a catback, my mods will be very similar, except 3.42s instead of 3.45s.
Old Dec 6, 2006 | 09:55 PM
  #59
Andy 91GTA's Avatar
Car: 91 GTA & 92 GTA & 92 GTA
Engine: 305 TPI & 350 TPI & 350 TPI
Axle/Gears: 3.42 & 3.23 & 3.23
Originally Posted by Lucid
Thats pretty good, thanks for the info.
Andy
Im thinking with headers and a better Y-pipe you could break into the 14's...
Nick
Thanks for the info, debating whether to slap some 3.08's or just rebuild the rear end and put 3.23's.
Hey Lucid. Next year I am likely going to install a Magnaflow cat, new AC Delco CR45TS plugs, learn how to do some tuning, and fix my intake manifold leak. Then I think I should run a 14.8. Once I've done that, I'm probably done modding my 91 GTA.
I bought a 92 GTA 350 TPI from California in September that I am in the process of fixing up and I am going to do a few mods to it too. Right now it is bone stock, it even has a paper air filter.
Old Dec 7, 2006 | 12:13 PM
  #60
Lucid's Avatar
Car: 86 Camaro Z28/ 87 Camaro IROC Z28
Engine: 5.0L TPI LB9 / 5.0 TPI LB9 w/cam
Transmission: Built 700R4 with Transgo shift kit
Axle/Gears: 3.27 9 bolt Posi/ 2.73 10 bolt Posi
Andy
That sounds good, get the biggest cat you can fit on there (make sure its a high flow one), i have 3" exhaust starting with/from the Cat going to the big Borla muffler. The 305 engine is also very sensitive to timing. With the timing at around 0 deg base, i was running 16.8 in the quarter, and bumping it up to 10 deg base at the track, i dropped it down to 16.2.
Good luck with the GTA
Old Dec 7, 2006 | 02:08 PM
  #61
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
12.31@108mph n/a and still daily driven...but i'm carbed...
Old Dec 7, 2006 | 08:11 PM
  #62
canadian250's Avatar
Car: 1985 WS6 T/A
Engine: LB9 305 TPI
Axle/Gears: 9bolt 3:27
Looking to get it going a little better after I change the cam over the winter!
Old Dec 9, 2006 | 06:46 PM
  #63
littletank170's Avatar
Car: 1987 LB9 IROC-Z
Engine: stock 305
Transmission: stock 700-R4
my '87 LB9 iroc runs 15.5 @88.2. i have managed a 2.16 '60 foot time, hooks up good but doesnt pull hard. all i have done to it is a TPIS airfoil and a GMS adjustable MAF sensor.
Old Dec 9, 2006 | 11:44 PM
  #64
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
That car is just plain nasty... man i know some people with built 383's that cant even pull those numbers!!
Old Dec 10, 2006 | 10:08 AM
  #65
mw66nova's Avatar
Engine: 7.0L
it's getting there...people don't believe it's a 305 anymore though...it's kinda annoying, in a cool way!
Fast355
Dec 2, 2016 06:33 PM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 10, 2015 07:44 AM
