EGR Vac Block
Old Aug 31, 2006 | 08:12 PM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
EGR Vac Block
I hope this is the appropriate forum for this.
Anyone know of a good place to get parts GM no longer carries? Besides the junkyard will be last resoirt but I'd prefer new), I need an EGR vacuum distribution block (that block with the two vac hoses near the dist and solenoid, one hose goes to the EGR). One of my lines have broken right at the base so a good fix doesn't seem possible.
Old Aug 31, 2006 | 08:32 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Are you referring to the actual solenoid?
Old Aug 31, 2006 | 08:53 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
Try TPIparts.net
Old Sep 1, 2006 | 11:44 PM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Originally Posted by DerekKraese
Try TPIparts.net
Bingo, thanks. I had been to the site before, but since I wasn't looking for this, I guess I didn't even think of the site.
Goose, this is what I was referring to. I got the name wrong initially, the Parts Catalog calls it the EGR Vacuum Harness.
89-92 TPI EGR Vacuum Hose
Old Sep 2, 2006 | 07:07 AM
Mongoose's Avatar
Car: 90 Formula
I've got one of those that I was going to use on my own TPI swap but have decided to disable the EGR instead. I'll sell you mine for cost plus shipping which would be the same total whether you bought it from TPIParts or me. Just let me know.
Old Sep 2, 2006 | 02:50 PM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Thanks goose, but I ordered last night before I posted, as I took the opportunity to order some stuff I needed.
Old Sep 2, 2006 | 03:11 PM
Mongoose's Avatar
Car: 90 Formula
Not a problem. Glad you got what you needed.
gta892000
Aug 11, 2019 11:16 AM
sailtexas186548
Feb 17, 2017 03:07 PM
92firebirdguy
Sep 1, 2016 07:53 AM
Kenwood
Sep 11, 2015 12:50 PM
rjcme
Sep 5, 2015 01:23 PM
