Car not starting
Old Sep 6, 2006 | 03:46 PM
subliminal's Avatar
Car not starting
I need some help diagnosing a problem with my car. It will not start I went to leave yesterday got it about 2 houses away from mine and it just cut off. I can hear the fuel pump come on and engage and it squirts out fuel out of the schrader valve when I press it. I took the ignition control module in to be tested and they tested it twice and said it was good both times. The cap, rotor, wires and plugs are all brand new. The only other thing I can think it might be is the Ignition coil itself, is there anyway to test it? Before it died on me completely it was dying out but then would start back up again after a few mins then it stopped dying out and I thought everything was fine and now it just did this. Thanks in advance for your help.
Old Sep 6, 2006 | 03:48 PM
Mr.Wolf's Avatar
Car: 87 Z28
Engine: uh does the name give u a hint
loose wire or short
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
L98GTA87
Aug 5, 2015 11:02 PM
