ignition troubles
Old Sep 9, 2006 | 05:11 AM
bahrstool's Avatar
ignition troubles
I can't get the car to start. I have spark at the plugs all the way around. I've replaced the module, cap, rotor, coil, plugs, wires. I disconnected the wire on the firewall and am at top dead center. All the wires are in the right spot but it won't start. I tried adjusting the tps, and it didn't work. Could the ECM be causing the problem?
Old Sep 9, 2006 | 11:16 AM
subliminal's Avatar
If youre getting spark it probably means youre not getting fuel. Hook a fuel pressure gauge up the the schrader valve on the fuel rail. Do you hear the fuel pump come on when you turn the key over?
Old Sep 9, 2006 | 03:53 PM
bahrstool's Avatar
i was messing with it today and got it started don't what i did because i dont even know. the problem i am having now is at idle, when i go to rev it up it is very sluggish until it reaches 2500-3000rpm before it seems to pick up. when in drive, i stand on the break pedal and slowly give it gas to see if it will turn the tires it won't go past 1000rpm. any ideas?
Old Sep 9, 2006 | 05:24 PM
subliminal's Avatar
Check for vacum leaks, check all the sensors to make sure theyre all set correctly.
Old Sep 10, 2006 | 09:06 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
No codes? What's your fuel pressure? Have you tried unplugging the MAF to note the result? Idle may be an issue b/c you played with the tps and you don't know yet what your fuel pressure is.
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
mrbird
Oct 20, 2015 03:43 AM
Lmancha96
Sep 25, 2015 08:11 PM
RedLeader289
Sep 23, 2015 06:50 AM
