injector ticking
Car: 1989 gta
Engine: L98 D1SC procharger twin IC
injector ticking
quick question guys ... i put a brand new set of accel 24lb injectors the other day.. the car runs fine but i noticed that some of the injectors pulse (when i put my fingers on the injectors) and some dont... is this normal that some injectors you can feel a tick and some dont ?
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
yes it is perfectly normal for some of the injectors to "tick"
i must add though that about 90% of the guys on this board will tell you that accel injectors are just terrible, high failure rate, bad ohm readings brand new out of the box, and other reasons that i cant remember. everyone here seems to prefer the ford svo injectors including me. i recommend get a set of those, but best of luck with the accel's
david068513
Sep 13, 2015 11:24 AM
