90-w-383 P600B Lean Tuning Issues ??
Old Sep 14, 2006 | 08:44 AM
dynomike299's Avatar
I have a 90 with a 383 with a P600 intercooled. I have 42lb injectors the code is AXYC with a $8 ECU and tuning the car with tunercat. In the scanner the inj Ms will only go to 7.3 and it stops there and the car goes lean. In normal conditions the Ms should be in the high teens @ WOT. I have maxed out the PE table to 50% more and it doesn't change the AF ratio. Any help would be great!!!
Mike
Old Sep 14, 2006 | 10:55 AM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
id post this is the dyi prom section...
Old Sep 14, 2006 | 09:48 PM
Z69's Avatar
Z69
And the answer you'd get would be-
8D PW limit fix. - Third Gen .org : F-Body : Chevrolet Camaro, IROC, Z28, Pontiac Firebird, Trans Am
You'll need an FMU and the posted fix above, or swap to $58 code. See DIY-Prom stickies for that.
PS- It's $8D
Old Sep 15, 2006 | 12:00 AM
Thanks for the info.........TC helped me out... the final......boost ,42's and this computer...doesn't work well.
Thanks Again
Mike
Old Sep 15, 2006 | 07:47 AM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
Hey -- I know who this is. The owner of J&M in manchester. or I suppose another guy named mike who works there...
How is buisiness mike? And what the heck are you tuning with a $26 ECU code?
By the way - this is the best source for GM OBD1 tuning on the web PERIOD.
Glad you found it.
Later
James.
Old Sep 15, 2006 | 09:40 PM
Yes it is, I've been working and learning on these chip based cars, what fun!!! There is so much more to learn here. These early computers are so much work compaired to the new stuff!! But the basics are the same.....
Great Fun
Mike
Street Lethal
Apr 30, 2019 12:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
billybob6110
Sep 24, 2016 09:50 AM
mizz0313
Aug 12, 2015 06:45 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
