coolant fan
Old Sep 14, 2006 | 02:46 PM
beneharris's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 350 T.P.I.
coolant fan
well my coolant fan never turns off when i shut the car off, it usually runs for a minute or so afterwards, and today it never shut off, so when i came out of school to go home my battery had died. it is ground to something that only turns on when the key is turned, so i dont know if the guy i bought it from ground it there cuz he thoughtit was a good idea or what... are they supposed to do that? what do you guys think
Old Sep 14, 2006 | 11:02 PM
robert1's Avatar
There should be a fan relay connected somewhere in the harness. Look for that and check it.
Old Sep 15, 2006 | 02:10 PM
battman's Avatar
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
Check the temperature sensor on the back side of the passenger side head. It may have fallen/melted off and grounding out against somthing.
Old Sep 15, 2006 | 08:29 PM
plndtx's Avatar
Car: '92 Heritage Z28 Convertible
Mine has done that a few times. I just cut the key to the on position (maybe cranked it) and back to the off position and the fan cut off.
The fan should cut off when the key is off. If you hear the fan running then it probably will not cut off on its own.
Try replacing the relay if they are not too expensive.
sheachopper
Jul 31, 2019 11:27 AM
Fanatic1074
Oct 2, 2015 03:47 PM
