WTF no change after header install
Old Sep 18, 2006 | 05:48 PM
bigjay89gta's Avatar
Car: 89 GTA
Before I installed hooker 2055 with y-pipe.
reaction .744
60ft 2.020
1/8th 9.202 @ 74.66
After the install only got a
.708 reaction
9.127 @ 76.00
Anyone know why my e.t didnt increase after install? I know it did a little but that was the best I could get.
Do I need a tune? Should I pump up timing and fuel? What should I do?
Jason
Old Sep 18, 2006 | 06:40 PM
90 white Z's Avatar
Car: 90 iroc
Engine: 305 tpi
why would your E.T. increase?? But i know where your going with this. You did drop a tenth and 2mph i guess thats a difference but with drag racing there could be many variables i.e. temperature (car and ambient temp.) As long as you have stock base timing and no other mods i wouldnt jack with the timing. Another thing, what do you have as far as cat-back exhaust you could have a clogged converter or the stock muffler would hold you back. Anyways good luck and let us know if your times change
Old Sep 18, 2006 | 07:05 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
You gained almost 2mph, thats good.
Old Sep 18, 2006 | 07:13 PM
Car: 89 GTA
I have a hooker catback no cat and a 3" electric cutout. I figured I would get better et. I am just disappointed. I figured I would at least hit the 8's with that.
Oh and my 60 ft for the 9.127 was a 2.018.
Old Sep 18, 2006 | 07:14 PM
Car: 89 GTA
humidity was lower and the temp was cooler on the last run. temp was 72 on last run(9.127) and 85 on first run(9.202)
Old Sep 18, 2006 | 07:16 PM
Car: 89 GTA
yeah and I meant decrease LMAO
Old Sep 18, 2006 | 07:56 PM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
the use of hedders will be more noticable in the full 1/4 mile run the gain you got was absolutely good no worries
Old Sep 18, 2006 | 09:13 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
thats what i was thinking.
thats actually very good. that would pro. be about 3tenths and 4mph in the 1/4. what other mods do you have.
Old Sep 19, 2006 | 04:42 PM
Car: 89 GTA
other then no smog that is it, stock rebuilt tranny free air foil.
So what can I do to get a better 8th time? Maybe do some suspension mods so I can launch harder.
Are my 60ft times good or could I be doing better?
Jason
Old Sep 19, 2006 | 05:06 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
actualy that was what i was thinking. you should be at a 1.9* 60'. but your still close. some shocks and tires should do you well.
Do you have traction problems. and a tune would do some good too.
Old Sep 19, 2006 | 05:38 PM
Car: 89 GTA
well some times I have traction problems. I ran one pass of a 9.247 with a 9.4 60ft.
I baby it out of the whole now when I got the 9.202 I gave it all it had so now that i think about it I need to figured out how to lauch it again since I got the headers.
Do you think I should play with the timing and fuel pressure? I just ordered a AFPR.
Old Sep 19, 2006 | 05:40 PM
Car: 89 GTA
" 2.4 60ft "
Old Sep 19, 2006 | 05:47 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Do you think I should play with the timing and fuel pressure? I just ordered a AFPR.[/quote]
that will help your hp, but you need to get that traction problem fix first imo.
Old Sep 19, 2006 | 05:56 PM
Car: 89 GTA
might see if I can borrow some slicks a guy down the street has a speed shop and has several drag cars a camaro and a chevelle. I just hope i dont break anything.
Old Sep 19, 2006 | 06:45 PM
Car: '88 Trans Am
Engine: 5.7L TPI
be careful when running drag tires the car runs fastest with 26.1 tall tires so a dragradial at 245/50/16 would be perfect,along with tires you need lca's,50/50 rear shocks,2600 stall with these parts you should 60' 1.7s
Old Sep 19, 2006 | 06:47 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
When I was moding my 89GTA installing the SLP Tri-Y headers was the single biggest seat of the pants improvement I made. I could really tell the horsepower picked up big time. All the other mods were incremental and not all that noticeable.
Old Sep 23, 2006 | 07:18 PM
Car: 89 GTA
well after installing my hooker 2055 I sometimes notice a big improve. Other time it just feels like it did before. weird
Old Sep 24, 2006 | 05:42 PM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
When I installed the exhaust system on my L98 car, it went way lean in the midrange, and needed the fuel pressure cranked up. It ran fine at high end, so that might be why your trap speed was good, but it just didn't pull strong through the midrange, so the ET improved only incrementally.
Old Sep 25, 2006 | 04:10 PM
Car: 89 GTA
that could be it because now that i think about it I can tell a big difference in the upper rpm range. So soons as I get some time of other then a few hours I will play with my timing and bump up fuel pressure when i get the AFPR installed. Thanks for the insite.
Jason
Frozer!!!
Jan 19, 2024 04:55 PM
Out-Cast
Mar 22, 2019 09:39 PM
Wesly_66
Aug 26, 2015 09:55 PM
mustangman65_79
Aug 7, 2015 09:55 PM
drathaar907
Aug 6, 2015 04:20 PM
