Broken Hose --- What is it?
Old Sep 19, 2006 | 08:20 PM
MiTHRiL's Avatar
Car: 93 TA, 92 GTA, 91 TA
Engine: LT1, L98
Transmission: T-56, 700R4
Axle/Gears: 3:23
I'm attaching a pic of a hose I found broken under the hood. You guys know what it is?
Old Sep 19, 2006 | 08:26 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
I believe that is the vacuum line that goes into the heater control valve.
Old Sep 19, 2006 | 08:53 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
It comes from the firewall. It goes from the HVAC control panel throught the firewall to the heater control valve.
Old Sep 19, 2006 | 09:04 PM
MiTHRiL's Avatar
Engine: LT1, L98
Axle/Gears: 3:23
It's plastic... Is it a special part? Would it impede anything since it's not hooked up right (besides heater)?
Old Sep 20, 2006 | 04:29 PM
MiTHRiL's Avatar
Engine: LT1, L98
Axle/Gears: 3:23
TTT. Anybody know?
Old Sep 20, 2006 | 05:01 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Transmission: 4L60
You can fix it with a regular vacuumn hose or they sell plastic lines and fittings at the auto parts store. As long as you dont move the climate control lever to heat you wont have a problem, otherwise you will have a vacuumn leak.
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
apie2546
Oct 16, 2016 02:24 PM
no green
Jan 9, 2016 09:22 PM
Reid Fleming
Oct 10, 2015 09:56 PM
