finally went to the track
Old Sep 23, 2006 | 05:31 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
Mods in signature im 17 and this was my first run i launched at idle in drive heres how i did.
r/t .256
60' 2.145
330 6.061
1/8 9.284
mph 75.64
1000 12.107
1/4 14.488
mph 94.92
How can run better any tips hows my 60 foot??
Old Sep 23, 2006 | 05:55 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Get a pair of drag radials of your choice. Then see how it hooks. Then work on your suspension mods/parts. Most people usually put money into the suspension first (me included) and then wonder why they didn't get much improvement in traction by doing it on regular radials.
Get sticky tires first and go from there.
Old Sep 24, 2006 | 11:32 AM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
did you spin any? you could lower you tire psi to get a better take off.
what was your timing set at? an AFPR would be a nice mod for you.
Old Sep 24, 2006 | 03:44 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
it felt like i spun alittle the tire psi was set at 25psi and my timing is at 10 in advance.
Old Sep 24, 2006 | 04:08 PM
Stevo's Avatar
Car: Pair of 92 Z28s
gears are killing you...as well as the 60' could be improved.
What i do or used to do when i had my auto is powerbrake it right till the point when the tires start to spin i think it was like 1200 rpm? then ease onto the gas and i managed a 1.9 60 ft on street tires.
You should see 13s with gears and a good 60 ft.
Bubbajones_ya
Oct 25, 2015 08:01 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
jaridjohn
Oct 5, 2015 07:01 AM
Numbah-1
Oct 2, 2015 08:27 AM
