tpi pro's inside please
Old Sep 24, 2006 | 11:52 AM
streetheatz28's Avatar
Car: 88 Sportcoupe camaro
Engine: forged 355
Transmission: th350
I have some problems with my 86 tpi 305 that I can't figure out. When I 1st crank it, it starts then cuts off then I have to turn it over for about 15 seconds before it starts. When cruzing at about 2500 rpm it studders and I have to floor it to make it stop and last the engine light comes on every now and then. I know it could be hundreds of things but anyone know if all of these could point to just one??
Thanks - charlie
Old Sep 24, 2006 | 12:08 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
How about you start by pulling the codes?
Old Sep 24, 2006 | 06:07 PM
Engine: forged 355
Transmission: th350
ok sorry that is a good ideal. I did the little wire test thing and the engine light flashed 2 times. Is that code 2 or 11 ?? Hope that helps you help me
Old Sep 24, 2006 | 08:51 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Try this TPI trick to see if it works in your case. Crank the engine over for a couple of seconds. Shut off. Then crank again. Most will start right up on the second start.
Old Sep 24, 2006 | 09:44 PM
dcjredline's Avatar
Car: 1989 Formula 350
My guess is going to be the MAF Sensor.
LT1Formula
Aug 20, 2015 09:36 PM
Thirdgen89GTA
Aug 20, 2015 12:11 PM
Sanjay
Aug 12, 2015 03:41 PM
