Bring Up the Cavalry!
Old Sep 27, 2006 | 02:18 AM
LuBu_Z28's Avatar
Car: 1991 Camaro Z28
Engine: 5.7L TPI
Transmission: 4 Spd. Auto
Wassup Fellas?! I have a question:
What can be done/added to a '91 Z28 with an L98 to bring the horsepower up to 300?
Thanks!
Old Sep 27, 2006 | 07:31 AM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Originally Posted by LB9GTA
Check in my sig.
I was about 375+
Old Sep 27, 2006 | 11:45 AM
GOY's Avatar
GOY
Car: Formula, a big red brick.
Engine: A Ford 351 Windsor... ?
Transmission: Dodge 727
Reasonably Hogged SLP runners (walls 80% removed, no cutting/welding)
Accel/Edelbrock Baseplate (avoid edelbrock if possible)
Trickflow or AFR heads
3.5 inch Mufflex exhaust, or 3 inch if "Common Opinion" sways you.
SLP headers
Cam in the 214/224 area
PROM work
I see no reason close to 300 *REAR WHEEL* horsepower couldn't be found here. You will be kissing the big torque bell around 3000RPM good bye, but what can I say? It's cheaper than the SuperRam, and still emissions legal - which the HSR isn't. It's about the best budget solution. Search posts under the user name "1989GTATransAm," he's put down 330rwhp/370ft.lbs tq with a similar setup to that listed above.
Also here another dyno chart (not 1989GTA's) with an edelbrock plate and mod'ed SLP runners... http://users.erols.com/gcwestph/dynorun17.jpg
Ohhhh - option number 2 would be a DIY remote mount turbo and cost a fraction of that amount.
starliner
Feb 9, 2016 08:18 PM
David Frans
Oct 31, 2015 08:12 PM
mfp189
Sep 27, 2015 09:25 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
tuningnewb
Sep 23, 2015 07:06 PM
