LG4 to L98 - TPI or not to TPI (*with some limitations*) that is the question
Old Oct 10, 2006 | 12:33 PM
MikeDwhoROCZImports's Avatar
Ok, here's my situation. I use my 87 LG4 5-spd IROC primarily for Auto-x. The car just isn't legal in F-stock...the LG4 doensn't have enough in it. I'm also getting tired of F-stock, so I'm moving up to E-Street-Prepared. Here's what I can do engine wise:
-Use any engine out of any thirdgen (except the TTA). The internals, heads, and cam must remain stock, but I can use ANY intake system and a full exhaust (headers back).
I'm obviously going L98, but I'm unsure if I should keep my LG4 CCC setup, or go full TPI. Here are my questions:
-The big one - if I'm going from full LG4, 87 camaro to full TPI, say, 89 Camaro, and I have what's more or less a "turnkey" engine (longblock with TPI, ECM, uncut harness, accessories, exhaust manifolds, MAF, intake, distributor), HOW MUCH OF A PITA IS IT? I know I have to drop the gas tank and run new lines, but is the wiring more or less plug and play into what I have in the car? Is this a six month project or a month project over a few weekends? What kind of debugging issues can I expect?
-What would you guys do? I would really rather NOT have an extremely complicated project on my hands, but, I recently failed emissions twice and daily drive the car at times for work - in which case I'll typically put on 300 miles or so a week - so the improved gas mileage is tempting. Furthermore, there's something to be said for fuel injection in a sport where response is so key.
TIA!
Old Oct 10, 2006 | 04:24 PM
GOY's Avatar
GOY
Car: Formula, a big red brick.
Engine: A Ford 351 Windsor... ?
Transmission: Dodge 727
If you are asking which you should go with, there's no question in my mind that TPI is the way to go over CCC. It is a bit of work however. If I were you, I'd look for a complete junk'er car to use and the donating vehicle so you don't get nickle and dimed to death like I did on one of the swaps.
Old Oct 10, 2006 | 07:28 PM
Damon's Avatar
Why not start with the L-98 with your current intake system and see how it goes? You can always spend more money and convert it to TPI later if you don't like the results.
The CC-Qjet system can easily run an L-98 with little or no mods. I'd suggest some richer secondary rods (DRs at least, like the L-69 305 HO used OR some even richer DA rods). I'd also suggest a fair bit more initial advance at the distributor than the stock LG-4 0* setting (at least 6* BTDC being a safe starting point for maximum scoot). If you can put an aftermarket chip in the computer that would be even better, rules permitting. Stock LG-4 spark advance curves are VERY conservative.
QJets have very compact fuel bowls and actually do quite well in high-G type maneuvers. Certainly nothing like the dead-nuts accuracy of fuel injection but damned good for a production carb.
Vintageracer
Jan 10, 2020 05:33 PM
NBrehm
Aug 25, 2015 11:49 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
