any help would be appreciated
Old Oct 20, 2006 | 03:09 PM
beneharris's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 350 T.P.I.
i went to start up my car yesterday, and it turned over for a second or two and then everything just lost power. the battery is fine, all of the fuses are fine, there is just no power going to anything in the car. it worked fine when i drove home from school, i shut it off, grabbed something from my room and tried to start it again and it just went out. could it be the battery cables? any other ideas?
Old Oct 20, 2006 | 11:28 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
it has to be a bad ground if the battery is good. Did you try to jump it to see what happened? Check your batter cables to teh battery, then follow them to see if everything is still hooked up.
Old Oct 20, 2006 | 11:53 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Fusilble link.
battery cables,
bad ground,
ignition switch,
Do some research from the battery forward.
Or write down what does and doesnt work and consult a wiring diagram for a place to start
Old Oct 21, 2006 | 01:13 PM
beneharris's Avatar
Engine: 350 T.P.I.
ok thanks. and ya, i did try to jump it. ill check the cables and the ground, thanks.
83RDRACR
Mar 26, 2016 08:13 PM
Formula8r89
Sep 22, 2015 04:24 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Denricci22
Sep 18, 2015 09:02 AM
