Experts, how much power can expect REALISTICALLY....
Old Oct 23, 2006 | 06:31 PM
PneumaticTire's Avatar
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
By polishing up the inners of my upper intake and runners on my 305 tpi? In other words is it worth the time? The only things done to the car so far is hooker 2055' 3 in y pipe and smog/cat delete. I do plan on a bigger cam, and a better rear. The 2:77 rear has got to go. lol. Right now the car is running good, timing at 6*BTDC. I do need to get a set of header style plug wires, and better plugs. I don't like how the rapid fires are performing.
Old Oct 23, 2006 | 08:11 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
to be honest in a 305 i dont think so. porting out the EGR walls by the TB might be ok, but even with that dont expect much more than some better throtle responce.
Old Oct 23, 2006 | 08:15 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Polishing? Probably not. Removing EGR walls and siamesing the plenum to the runners? Maybe. It's one of those jobs that I would hold off on until you have to take off the intake for a reason.
Old Oct 24, 2006 | 06:52 PM
That's what I have thought. I don't think I'm gonna bother then. K&N's will be next then.
Old Oct 25, 2006 | 11:30 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
well at this point the biggest bottleneck in your engine is the stock cam. You can port until your heart's content and you will still not notice much becaue the cam wont allow the engine to draw the extra air in. Get rid of your crappy cam and maybe do something with the heads and you'll be happy with the gain. see the sig.
Old Oct 25, 2006 | 11:33 AM
goober's Avatar
Car: 1990 camaro rs
Engine: rebuilt 305
where did you get a lingenfelter motor from
Old Oct 25, 2006 | 02:48 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
yeah you can see all my mods I did to my 305, it runs pretty good.
Old Oct 25, 2006 | 03:13 PM
Demon355's Avatar
What did your car put down power wise tenpin842?
Old Oct 25, 2006 | 07:48 PM
dave-92gta's Avatar
Car: 92 trans am/ 93 dodge spirit V6
Engine: L98 V8 - 350
Transmission: TH-700-R4
ok. im looking into the smog pump delete, and i was wondering what the EGR walls are. second what is siamensing the plenum? would taht be helpful in my 350?
Old Oct 25, 2006 | 08:20 PM
XSVortex's Avatar
3rd° Tech Tips~Porting the Plenum
Old Oct 26, 2006 | 01:22 AM
The EGR walls are the walls located right behind where hte throttle body sits. There is one on the bottom of each inlet hole.
Siamesing is when you basically blend two runner inlets together so that they form one figure 8 shaped (without the middle part) hole.
Old Oct 26, 2006 | 09:13 AM
dave-92gta's Avatar
siamensing the plenum seems like a lot of work, and a high risk for the gain. anyone out there have any dyno runs to prove if its worth it?
Old Oct 26, 2006 | 01:57 PM
Demon355's Avatar
Dave, most people will tell you that porting the plenum is useless and/or a waste of time, but in all reality you are making the incoming air direct itself towards the runners faster and smoother so I don't see why not? It's a free mod so I'd do it if I had the choice.
When I ported my plenum it literally took about 20mins for each side. Carbide bit and a dremel is all you need. Along with a few sanding discs to smooth it all out. To me, it's worth the time. I need to get cracking on my base to match my new AS&M runners now...
Oh and I don't have any real dyno proof if it effects anything, it's more piece of mind really.
Old Oct 26, 2006 | 02:39 PM
dave-92gta's Avatar
yea.. thats helpful, someone said before that you should jsut do it when your plenum is off, so i think i might do that when i take my smog **** out. oh about that, i was reading the tech article on this, but it erally does not give me any info about it. for those of you who have done it, and tips on what i should look for?
Old Oct 26, 2006 | 02:43 PM
Demon355's Avatar
I kept my EGR in place but I removed the smog pump and all the tubing that went with it. My car being an '87, I didn't need to get a smog pump delete pulley.
BRoss99
Aug 10, 2025 05:08 PM
Cornholio7979
Sep 20, 2018 02:31 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
sailtexas186548
Aug 24, 2015 10:11 PM
ezobens
Aug 19, 2015 10:29 PM
