What controlls the electric fans?
Car: 87 formula
Engine: 5.0 TPI
Hey guys, the electric fans on my firebird stopped working and I'm wondering what the culprit is. So far I ran a switch to jump two wires to make the fan(...or fans not sure..) spin. I just got a new chip (hypertech, crap I know) put in because the old one was broke, so I was wondering if the problem with my fans not coming on is in the chip or the computer or something else, thanks!
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
If you have dual fans, one is controlled by a simple temperature switch in the passenger side head. The other fan is controlled by the ECM.
Car: 1989 GTA
Engine: 5.7 TPI
Transmission: A4
The primary fan on the driver side is governed by the chip, according to certain variables. The secondary is switched by the temp sensor or AC pressure switch(when you turn on AC.)
Can you find a stock chip for your year/transmission? It is possible you got a corvette chip, where the fan polarity is switched.
Car: 92 trans am/ 93 dodge spirit V6
Engine: L98 V8 - 350
Transmission: TH-700-R4
yea my fans are really messed that way to.. like the first fan.. the once controled by the temp, it will run when i first start my car... and then it will cut in and out all the time at random times.. like it only started doing this.. it usto always run.. and the second fan runs good off the ecu, i also have it off a switch. but i know what you mean... iw ant to switch up my temp controle. but i cant find it. i was reading a bit in the website here but no luck... so where is this temp thing anywho?
Car: 87 formula
Engine: 5.0 TPI
Well, I think they were working before a couple of weeks ago...My dad said he already replaced the temp sensor and the relay and it did't help, it's a dual fan setup, would there be any way to find out if it got a corvette chip?
edit: I just wanted to add I'm not 100% sure on if they were working or not and I re-read my first post and can't believe i forgot if it was single or dual fans, lol, guess I was up too late, and thanks for the info.
Car: 1989 GTA
Engine: 5.7 TPI
Transmission: A4
I am not sure if hypertech has a part or chip number on them or how they identify their chips. That would be the first thing I would find out and contact hyperchips for info on what you have.
Car: 87 formula
Engine: 5.0 TPI
Alright, thanks guys. I need to get my truck inspected, so I'll see if they can give me the part number of it or something before I go taking the dash apart.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
