siamesing, porting, etc...
Old Oct 25, 2006 | 05:14 PM
85s10tpi's Avatar
Car: 88 gta 305 tpi in a 85 S-10
Engine: 88 maf LB9 T.P.I.
Transmission: 700r auto st.2 kit
Axle/Gears: stock 3.44 s-10 diff
Is it worth all the trouble port matching stock heads porting stock plenum and siamesing stock runners if you have stock LB9 5.0? I only have minor upgrades (shown below) and i am going to get a chip burned soon.... and does anywone have some numbers and pics of a mildly modified engine and the porting process shown in detail? ( notice I said stock many times I want to keep cost to bear minimum)
any help woould be aprecieated
Old Oct 25, 2006 | 05:25 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
I really don't think that it would be worth it. Someone else just made a thread basically asking this, and I'll tell you what I told them:
Unless you are taking off the intake for a reason, it's really not worth the hassle. You have 2 things going against you in terms of porting being effective:
You are running the 5.0
You dont have the modifications that would require more airflow (heads and cam)
So your gains would be minimal, and not really worth taking a weekend and dedicating it solely to porting a stock intake. Wait until you put a set of heads on the motor, when the intake NEEDS to be taken off you know?
But hell, if you have the time, go for it. You might see 10hp if you are lucky, but closer to 5hp from what I have seen around.
Old Oct 26, 2006 | 12:14 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Do it , every little bit helps on them motors . Seeing how there isn;t much aftermarket heads out there. Like said if you got the time ....do some research on here and give'r .
Old Oct 27, 2006 | 12:19 AM
navyCM's Avatar
Car: 87 IROC
Engine: 5.7 TPI
IMO the better an engine breathes the better it will run. Youll see a small gain from your current mods. Its really your call if you want to do it or not. But if your going to tear into why not get an aftermarket set of runner and port match to them. Cost for aftermarket runners is not all that much and youll see a real nice gain after the work is done.
Old Oct 27, 2006 | 12:40 AM
Drac0nic's Avatar
Intake porting
This is my porting stuff, heads are in the next section. I just wanted to have you consider something before you go along with porting the heads and intake. To really do it right (new head bolts, new head gaskets intake gaskets etc) expect to spend $150 if you REALLY do it right. I got a set of 305 HGs off ebay for $35, a set of bolts for $35, the runner gaskets cost me $20 the valve springs were another 35 and probably some misc. stuff thrown in there. Honestly, if you were in there I"d just do the cam while you're at it. If you do h/C/I you'll be surprised how far it'll take you probably.
Old Oct 27, 2006 | 03:09 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
At least do the plenum and runners. I siamesed my plenum and radiused the runners and gained a tenth in the 8th and quarter on a 350 after another member on here claimed to have gotten 2 tenths out of the same mods on a 305. Take out the EGR walls and at least radius the dividers, it takes about an hour with a die grinder, is good experience, and will help your car out. I just did the base, I put a post up with pics comparing the new base to the old one; this was a PAIN but I'm glad i did it because one of my roller lifters was eating up a cam lobe so i'm going to change it out and try to get one more pass in this season. The base is alot more entailed but I'de say there's good gains to be had there. Look for my post, i have pics of my stock heads; you can see how big of a restriction they are. None the less porting is free minus the time and the gaskets, and you will notice a difference if those are your current bottle neck (which they will be after gutting the air box, installing good filters, and opening the exhaust).
Old Nov 2, 2006 | 12:36 AM
neagan's Avatar
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
Re: to port or not to port...
Definitely invest the time to do it all.
You've gone to a hella' lot of trouble to take your 100 horsepower into something with Pitbull teeth. I bet you have a great time shutting down unsuspecting road racers!
I cut my hot rodding 'teeth' (so to speak) on a 1988 Toyota pickup with the 103hp 22r engine. Mechanics would scratch their heads and laugh at me for spending vast amounts of time and effort to gain 2-5 horsepower out of an upgrade or modification. I don't know how many times I heard 'proffesionals' tell me that 'I won't even feel that small amount of horsepower'. But when I was done, I had a sleeper minitruck that would turn and stop on a dime, shut down stock mustang/camaro's, easily burn rubber in 2nd gear, embarass other show-off drivers, and never broke down in 200,000 miles. Every little bit helps and I think what you're doing with your truck is fantastik!!!! However, you already know that and don't need me to tell you to keep on kicking a$$!!!
WOW!!! Was that porting attatchment full of EXCELLENT info or what!!!!!
Have you got any good pic's of your 'monster truck'???
Kudo's; Nitro
Old Nov 2, 2006 | 09:26 AM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
Originally Posted by Drac0nic
Intake porting
great article.
Linson
Oct 24, 2025 02:00 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
mattcanty
Oct 12, 2015 11:08 AM
Reid Fleming
Oct 10, 2015 09:56 PM
bplessy
Sep 30, 2015 12:14 PM
