wiring ??'s
Old Oct 29, 2006 | 03:15 PM
scamaro355's Avatar
Car: 92 rs
Engine: 355 stealth ram, dart heads, S480
Transmission: 4L80E
wiring ??'s
im in the process of goin from a tbi to a steath ram in a 92 rs i got a harness from a 92 z-28 for the wiring the problem im having is i have a wide flat 4 plug that i cant seem to find where it goes its wired into the distributor and coil im lost any help??...or a link to a good wiring diagram
Old Oct 29, 2006 | 08:29 PM
pmpn's Avatar
Car: 1989 GTA
Engine: 5.7 TPI
Transmission: A4
You should have two connectors to your dist (actually the ignition module.) One goes to the coil (three pin) and the other goes to the ECM (four pin.) You should have two connectors to your coil. One is from the dist (again, three pin) and the other is from the ignition switch/instruments (2 pin.) Good luck with the swap!
Old Oct 29, 2006 | 08:35 PM
pmpn's Avatar
Car: 1989 GTA
Engine: 5.7 TPI
Transmission: A4
I tried to find out where the four wire connector terminates to the ECM but I guess Haynes doesn't know either, sorry!
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
