Start Problem
Car: 89 Iroc Convertible
Start Problem
Had an unusual thing happen today.I was driving my 86 Iroc 305 tpi and everything was fine till I stopped to get gas.After filling up i got in the car and turned the key and nothing happened.The motor didnt crank,there was not even a click.It made no sound at all.This has never happened before.I had all other electrical functions.I popped the hood and wiggled the battery cables a bit but nothing.I did hear what appeared to be a hissing noise from I think the fuel rail or injector(s).Finally after about 10 minutes when i was about to give up I tried 1 more time and it started right up.Drove it home shut it off and it started right up.Any Ideas?
I thought it might be that also.I did try to start it in neutral but nothing happened
Car: 1986 Camaro Z28
Could be heat sepage(I believe is what they call it...)....when the starter gets too hot, it draws too many amps, and is not able to turn over, but does wear the battery out, although, with this, you should still hear your starter solenoid clicking, and it should still turn, just really slow, and not enough to start it...
Car: 1988 IROC -Z28
Engine: 5.7L TPI
Axle/Gears: 2.77
A buddy of mine has a 92 TransAM that occasionally does the same thing. I've determined that it's heat soak, there are products to help you with that, just search heat soak
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
The same exact thing happened to me in my Datsun 280ZX about two weeks ago. I think it was the neutral safety switch becuase after a bunch of
i decided to move the shifter through the gears one more time just for the hell of it and it aparently decided to get a sense of humor and start up right away with no fuss. Havn't had a problem since which is a little odd to me, but oh well.
i decided to move the shifter through the gears one more time just for the hell of it and it aparently decided to get a sense of humor and start up right away with no fuss. Havn't had a problem since which is a little odd to me, but oh well. Thread Starter
I think it might also have something to do with heat.I dont really drive the car too much but that day i drove it to work then took a long fast ride.It was fairly warm out that day thats why I thought something might have gotten too hot.10 minutes later it all ok again
Car: 1991 Camaro RS
Engine: 305 TBI L03
I've had the same thing happen to my car several times. We replaced the neutral safety switch and it was fine for a long time. But the other day I went out to start my car, the temperature was about 40*F, and it happened again. Waited about 10 minutes, and it started right up.
92camaroJoe
Aug 13, 2015 06:07 AM
