barely starts
Old Nov 5, 2006 | 08:16 PM
jjlabinski's Avatar
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
barely starts
I just finished my engine and started it for the first time. The engine wont run for more than 10 seconds by just turning the key without me openeing the butterfly on the TB.
Wont idle low enough to set ingnition timing.
fuel pressure about 52 psi with engine ideling as well as I can get it.
24 lb injectors
any thoughts?
thx
jeff
Old Nov 5, 2006 | 08:54 PM
neagan's Avatar
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
Re: idling issue..
Can you add a little more information? we have no idea which engine or year you have, if it's basically stock with some sort of larger injectors? Does the idle smooth out at all? If it does, what RPM does that happen at, what is the idle RPM when it first fires, does it change once it comes up to temp?
first wild guess would be to have you spray carb cleaner all around the intake plenum to eliminate vaccuum leaks. Other than that, you';ve got to help us help you. Nitro
Old Nov 6, 2006 | 04:45 AM
jjlabinski's Avatar
Engine: shinny 350
377 engine
112 lobe separation on cam
52mm bbk throttle body
10.3 compression
everything ported large and matched
24lb accell injectors
roller engine
lowest rpm 1100
havent run it long enough to notice any changes.
heard valve train sounds i was unfamiliar with so I shut it down.
thx
jeff
Old Nov 6, 2006 | 09:42 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
who adjusted your rockers?
Old Nov 6, 2006 | 05:11 PM
jjlabinski's Avatar
Engine: shinny 350
me, I just put another 1/4 turn into them. everything was zero lashed but as I explained to the tech at comp cams when I installed the roller lifters some of them were not pumped up all the way and some were. I was told it did not matter and I was going to final adjust after the engine was warm and ideling
thx
Old Nov 6, 2006 | 07:26 PM
jamon8's Avatar
Engine: 350 tpi
this happened to me once when I was not on no 1 tdc
instead I was on no 6 and my valvetrain made noise and would not run right
Old Nov 7, 2006 | 03:20 PM
jjlabinski's Avatar
Engine: shinny 350
was it your distributor or cam that was 180 out?
Old Nov 8, 2006 | 05:33 PM
jjlabinski's Avatar
Engine: shinny 350
my distributor was installed correctly
92camaroJoe
Jul 29, 2023 07:57 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
perZ
Aug 21, 2015 05:51 PM
92camaroJoe
Aug 13, 2015 06:07 AM
