For those with AS&M runners, lower bolts
Old Nov 13, 2006 | 12:14 PM
HD4mula's Avatar
Do you have to take the valve covers off to install the lower runner bolts? It was tight before but now I can't do it. My vavle covers are about 1/4" taller than stock. I think that definitely doesn't help my cause
Attached Thumbnails For those with AS&M runners, lower bolts-img_5568rs.jpg   For those with AS&M runners, lower bolts-img_5569rs.jpg
Old Nov 13, 2006 | 12:20 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
ya. and you will have VC problems. I had to trim the lip to get the covers between my pro mags and runners.
Old Nov 13, 2006 | 03:35 PM
HD4mula's Avatar
Thanks. I am using Summit narrow rockers.
Old Nov 13, 2006 | 04:12 PM
Guest
Guest
Posts: n/a
These are the kind of things I dont want to read.
Ugh.
The price of going fast.
Old Nov 13, 2006 | 06:13 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Narrow or not its the clearance between the top of the rocker and the runners. I accually had to grind where each rocker was hitting the valve cover rail on the my valve covers so it would slip by without scratching the runners.
Old Nov 13, 2006 | 06:49 PM
HD4mula's Avatar
I understand what you are saying but I don't have that problem. I installed one runner and was able to easily put the valve cover back on without any clearance issue. So your cover/rocker combo is the problem. Are you using stock valve covers?
Old Nov 13, 2006 | 10:48 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
No. Both my Miloden and my GM PP valve covers did the same thing.
tazs2000
Jul 15, 2017 08:44 AM
deracer
Apr 11, 2016 12:04 AM
Hawkeye1980
Aug 31, 2015 07:09 AM
knight72
Aug 10, 2015 09:32 PM
