HESITATION
Old Nov 14, 2006 | 05:11 PM
1989GUNMETALTA's Avatar
HESITATION
OK WELL I JUST GOT MY CAR BACK AND MY FUEL PUMP RELAY WAS FRIED. I CHANGED MY OIL PRESSURE SWITCH CAUSE IT WASNT SHUTTIN OFF. NOW PRIOR TO AND NOW ,WHEN I DRIVE MY CAR IT HESITATES BIG TIME, IN THE BEGINGING THE CAR IS FINE, BUT AFTER IT WARMS UP IT SEEMS LIKE IT DOESNT WANNA GO. WHEN I HIT THE GAS, IT DOESNT ACCELERATE, IT TAKES A SEC THEN ALL OF A SUDDEN KICKS IN. IT IDLES FINE, AND RUNS FINE, BUT THE TOP END ISNT THERE AND IT HESITATES. LOOKING FOR SOME HELP. PLEASE AND BEFORE U SAY ANYTHING I AM SORRY FOR THE CAPITAL LETTERS, I WEAR GLASSES AND IT IS EASIER TO SEE, SORRY.... THANKYOU FOR YOUR HELP AND TIME....
Old Nov 14, 2006 | 05:21 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Get thicker glasses :-)
I wear them to and can get along just fine lol
Anyhow.
Any codes?
Have you checked for the basics?
Kinda hard to help you out with vague descriptions.
U could be looking at anything from bad grounds to bad injectors or TPS or anything in between.
U need to start verifying things.
later
Jeremy
Old Nov 17, 2006 | 12:15 AM
Lucid's Avatar
Car: 86 Camaro Z28/ 87 Camaro IROC Z28
Engine: 5.0L TPI LB9 / 5.0 TPI LB9 w/cam
Transmission: Built 700R4 with Transgo shift kit
Axle/Gears: 3.27 9 bolt Posi/ 2.73 10 bolt Posi
You should pull a couple spark plugs and look at them, and check your plug wires and make sure you dont have any burn marks or breaks.
Old Nov 19, 2006 | 06:38 PM
THANKYOU FOR ALL UR HELP. IT WAS MY MAF.
Fanatic1074
Oct 3, 2022 05:57 AM
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
85 Jimmy
Sep 30, 2015 07:56 AM
RedLeader289
Sep 23, 2015 06:50 AM
