Intake Runner Tube Problem?!!?!?
Old Nov 18, 2006 | 08:16 AM
bigtom88transam's Avatar
Car: 88 trans am, and 06 focus DOHC
Engine: 305 tpi
Axle/Gears: 4.56 screaming pave eating :-)
Hey all im back and not selling my car lol but i have a problem i cant seem to figure out.....i changed the plugs, and temp. sensor but my car when it runs 6 out of 8 of the intake tube runners are warm except for the rear 2 they are ice cold! what could be the problem ??? this is 5.0 tpi motor. i think thats where my fuel dumping problem lies any ideas??: mad:
Old Nov 18, 2006 | 01:30 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
is it running rich?
if so the diaphram in the fuel reg maybe the problem. does it runn good?
Old Nov 18, 2006 | 03:22 PM
Engine: 305 tpi
Originally Posted by 3rdgenZ
is it running rich?
it runs pretty good yeah just apart from the running rich problem
someone i know said that its normal for some of the tubes to be ice cold because of the water jackets.
someone was saying the fuel pressure regulator may be bad for rich problem
what u tihnk ?
Old Nov 18, 2006 | 08:14 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
what u tihnk ?
pull off the upper intake and check the reg. be sure to release the pressure in the line first. if you see gas on top of the diaphram, thats your problem.
do you know how rich it is, some air fuel ratios might help. some times even when its smells rich, it might just be running fine. my little 305 always smelled like it ran rich. but the mixture was fine. i never found out why it smelled so bad though.
Old Nov 19, 2006 | 12:05 PM
Engine: 305 tpi
well that info just might help me... im not too sure what ratio is when i hooked it up to the scanner but all i know is i was getting 145-150 cfm of air g oing through the MAF sensor which is fine..... would you know also why fuel would dump into the cat and blast out exhaust very loudly?? sounds like shotguns off.... maybe bad misfire any ideas???
1992 Trans Am
May 10, 2023 07:19 PM
mdtoren
Aug 23, 2015 12:52 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
Street Lethal
Aug 12, 2015 11:33 AM
mustangman65_79
Aug 8, 2015 12:07 PM
