Serpentine Belt Brackets for an 87' 305
Old Nov 19, 2006 | 03:42 PM
92IrocRS's Avatar
Car: '92 RS ~ '92 Ranger
Engine: 305 TPI ~ 2.3 OHC
Transmission: 700R4 ~ Mazda 5-Speed
Axle/Gears: 10-bolt 3.23's ~ 7.5
I really need to find a company that sells a kit or something to change over my v-belt to a serpentine system. All I need is the alt., p/s pump, water pump, and obviously the crank, but I haven't been able to find anyone that sells them. Anyone know a reputable place to go????
Old Nov 19, 2006 | 05:57 PM
lakeffect2's Avatar
Car: 1993 Caprice wagon "Shammoo"
Engine: tpi'd 406, with P4 ebl EBL 730 ECM
Transmission: custom "4L65" swap.
Axle/Gears: 3.42:1 with posi
Can't say if this will help but...
I'm driving a 93 Caprice. The driver's side serpentine bracket supports the Alternator, P/S pump. The Waterpump and Crank are on the block itself of course. Keep in mind this was setup for a reversed direction pump. and you'd lilely need to throw an idler pulley in some how. The passenger side has rthe A/C, air pump and tensioner. If you are running a/c (which you did not mention) then it becomes easy to use both brackets, and a 95" belt, by passing the air pump.
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Jan 9, 2020 08:29 PM
Genopsyde
Nov 11, 2015 10:46 PM
mustangdmurder
Aug 21, 2015 07:17 PM
jahblah
Aug 12, 2015 05:54 PM
