Idle problems
Old Nov 23, 2006 | 06:12 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
Idle problems
I have a 1986 Trans AM V8 5.0 FI TPI. My car's idle is way off! My gauge needle jumps back n forth gasping for air or something and then dies/stalls after 15 seconds unless I give it gas and drive it. I've checked the vacuum lines and I just cleaned my plenum and put in new gaskets. Does anyone think all I have to do is clean/replace my IAC sensor or what? Has anyone had this problem before and what did you do to fix it?
Old Nov 23, 2006 | 07:04 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
try unhooking your battery for about 5 minutes ,it lets everything reset itself.hope it helps.later jimmy
Old Nov 23, 2006 | 07:10 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
Try cleaning the IAC and do the adjustment procedure. Seems to be the cause of a lot of idle issues. Badman
Old Nov 23, 2006 | 09:29 PM
Bobby_80s's Avatar
Axle/Gears: no idea
thanks
thanks I already had the battery unplugged from doing other repairs to replacing the EGR Valve and Solenoid and cleaning the plenum. I will try cleaning my IAC and the idle speed setting procedures. I just want ideas thrown out there that I haven't thought of yet and if I need to start looking into other possible causes for my idle being way off.
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
perZ
Aug 15, 2015 01:17 PM
