NEAR STOCK TPI ET'S... :-(
Old Feb 17, 2007 | 02:01 PM
  #51
MARO-MAN's Avatar
Car: I've had 4 thrid gens!!
Engine: Someday again I will have another!!
Wow, thats one of the better threads I have read on this board. Was impressed to see such an improvement from just new tires and tune up.
You got a 1.8 or 1.9 in the 60' with street tires? Stock suspension?
Old Feb 17, 2007 | 04:27 PM
  #52
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
Axle/Gears: 9 BOLT/ 3.27 GEARS
No. my 60 times were in the 2.1-2.2 range. Hopefully I can get my car to dip in the 1.9's so I can run 13's. It will probably take some sticky tires.
Old Feb 17, 2007 | 10:37 PM
  #53
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
Well it wasnt just the tires and the tune up. I did remove the smog pump, descreen the maf, bypass the throttle body, added an air foil and Accel ignition module, and advanced the timing a few degrees. I also recharged the flux capaciter too!
Old Feb 18, 2007 | 08:43 AM
  #54
MARO-MAN's Avatar
Why not say "I advanced the timing and added a couple things", in the first place?
Oh, and just change the flux capaciter, why fuss with recharging it all the time?
Old Feb 18, 2007 | 11:09 AM
  #55
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Originally Posted by ws6gta89
If i were you i would move up to a set of 3.73 gears once you get the new setup to really use the upper rpm power you will have.If you car isnt a daily driver then i would go 3000-3200 stall
if you have a lock up converter in the trans, then 3200 wouldnt be a bad choice. you can daily drive that. i know guys doing 3600 stalls daily drivin
Old Feb 22, 2007 | 03:16 AM
  #56
ws6gta89's Avatar
Car: 1989 TRANS AM GTA
Engine: 355 L98
Transmission: Built 700r4
Axle/Gears: BW 3.27
If i had a stall that big i would have to sell my car because i would blow through to many tires and tickets
Old Feb 22, 2007 | 03:55 AM
  #57
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
I think a 3,200 stall should be perfect for a daily driven HSR setup with Vortec heads. I'm gonna run a decent sized cam too! My springs are rated to .550 lift. I don't really wanna push .525 though. I want my drivetrain to be safe and my computer easily tuneable!
Old Feb 22, 2007 | 06:42 AM
  #58
ws6gta89's Avatar
Engine: 355 L98
Axle/Gears: BW 3.27
Do It!Do It Now!
gta90
Sep 15, 2015 04:00 PM
jbd1969
Aug 17, 2015 07:06 PM
Sanjay
Aug 12, 2015 03:41 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
marcusaw
Aug 10, 2015 08:13 AM
