What year did throttle bodies/throttle cables change?
Old Dec 4, 2006 | 08:30 AM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Hi guys, I know the TPI throttle bodies have two different style throttle cable mounts, depending on the year. What was the cutoff year for the new cable? Will my 1987 throttle body use the same cable as a 1989 TB?
Old Dec 4, 2006 | 03:31 PM
jack harrison's Avatar
Car: 1987 pontiac trans-am
Engine: 350 tpi
Axle/Gears: 3;73 with eaton lsd
i think it will. when you see t/bs advertised in the mags and online they refer to 85 to 92 (tpi) then the 93 to 95 (lt1) im guessing an lt1 tB wouldnt go on a tpi, so that later one you have, as long as its tpi, should go on ok. hope this helps. (and makes sence!)
Old Dec 4, 2006 | 03:38 PM
Car: 2000 BMW M5
I found out the answer. 1985-88 and 1988+ TPI have different throttle body arms due to different throttle cables, as I suspected. They will not just bolt up. The aftermarket TB's have screw on attachments to compensate.
Old Dec 4, 2006 | 03:41 PM
Engine: 350 tpi
ah, well done!! now i know!!
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
maroe624
Apr 16, 2017 08:29 AM
timonator
Aug 13, 2015 11:27 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
