BIG PROBLEM!!
Old Dec 6, 2006 | 02:44 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
BIG PROBLEM!!
big problem.. i was reinstalling my adfpr since the top bolt seemed to get stuck and un able to adjust my pressure or lower it.. so one of the six torx bolt broke in side the thread of the fueal rail .. the end part.. the head of the bolt broke... i was unable to take it out.. so i kinda drilled right in the middle with a really really samll drill... and it went right through.. unfortunately it was imposible to take it out.. left it as is and but a little bit of jb weld just in case gas flows through.. would this be safe using 5 instead of 6 bolts to hold down the bbk fpr... it looks to me like its not leaking any gas or such.. i dont want to drive it unless it looks safe...
Old Dec 6, 2006 | 03:39 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
I would fix it properly. get a eazy out set.
Old Dec 6, 2006 | 05:17 PM
joejoe's Avatar
Car: red one
Engine: on the floor
Transmission: next to engine
Axle/Gears: the ones that turn
You could find the thread size, drill it, and tap it.
Old Dec 6, 2006 | 09:27 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
If all else fails you can get a complete FPR housing from GM but it is no cheap.
Old Dec 6, 2006 | 09:40 PM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
If you are looking for someone on this site to say "sure its fine just use the 5. It will work excellent" I doubt anyone will tell you this. Use common sense and ask yourself if this does leak and catches fire is it worth it?
Old Dec 6, 2006 | 09:48 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I would try it. The worst it can do is leak. Put it back together prime the system a few times. If all is dry and good test it out.
Old Dec 6, 2006 | 10:29 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
been driving it all day no leak... pretty soon ill be ordering the stealth ram.. alot easier to work on too!!
Kevin91Z
Southern California Area
Sep 16, 2015 03:00 PM
gixxer92
Sep 1, 2015 04:32 PM
lt1z350
Aug 28, 2015 05:57 AM
overdriv
Aug 20, 2015 03:52 PM
sreZ28
Aug 14, 2015 07:48 PM
