belt size w/no smog and u-pulleys?
Old Dec 15, 2006 | 08:05 AM
dv013003's Avatar
Car: Firebird Formula 350
Engine: 5.7
Hey,
I checked the tech article on re-routing the belt to bypass the smog pump and it gives the # of the new belt you'll need even if you have underdrive pulleys. It says the belt is about one inch shorter than stock.....
Is this for underdrive pulley sets that replace just the smaller crank and alternator pulley's or the set of 3 underdrive pulleys?
Also, i have an 89 350 tpi, what do you do with the two wire connectors that go into that black box after you take all the smog junk off?
Old Dec 15, 2006 | 09:34 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
just tape off the wires, cut them short and tape them up. Thats all I did on my 87 and my friends 89.
Now the belt....he has the alternator, power steering, water pump, H ballancer, and his A/C. He took the specs off the site and went to to Advanced auto and ordered the bely by the size and it fit perfect.
Old Dec 15, 2006 | 10:09 AM
dv013003's Avatar
Engine: 5.7
Thanks for the wire info....but I only have the march crank and alternator underdrive pulley...any idea on what belt size after rerouting to avoid smog pump?
Old Dec 16, 2006 | 01:54 PM
MdFormula350's Avatar
Is this the routing your doing?
If I can find the number when I get home I will post it.
5060930 thats the number on my receipt.
Size: 93" long by .82" wide with six ribs according to a site that stocks that number.
It was a custom one where I took the one that fit before the March power amp series underdrive and bought two belts that were a bit smaller. tried both and one of them work and took back the other one.
I have been running the pullies and new belt for 10k miles, everything seem to be working great. charging is normal, and battery is liking it.
I just cut off any connectors and tapped the wires that went to that smog stuff.
Old Dec 19, 2006 | 09:44 AM
dv013003's Avatar
Engine: 5.7
excellent
awesome...thank you for the help....also, what brand belt is that number for???
thanks man
Old Dec 19, 2006 | 09:54 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
only thing different with that pic, it it has no A/C. But pretty much the same set up.
Old Dec 19, 2006 | 06:21 PM
dayco it was like 25 bucks i think.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
m00n420
Sep 11, 2015 02:39 PM
MORREALE5
Sep 10, 2015 08:58 AM
buckshot63
Interior Parts Wanted
Sep 3, 2015 08:10 AM
