question about setting idle screw
Old Dec 15, 2006 | 01:53 PM
sting's Avatar
Car: '87 TransAM
Axle/Gears: 10 bolt 3.23
let the IAC click for a minute, unplugging it, disconnected timing wire.
if i back the idle screw all the way off the blades so it is not pushing them open at all, when i try to crank the engine over, should it run? (no air getting through?) or what should the general RPM be with the blades no opened and the IAC disconnected..?
Old Dec 15, 2006 | 03:30 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
You need to adjust the idle screw while its running. Do no back it all the way off and then start it cause it will not run.
Old Dec 16, 2006 | 02:15 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Read the tech article posted on here.
later
Jeremy
Old Dec 16, 2006 | 10:06 AM
sting's Avatar
Car: '87 TransAM
oh you know what happened, i would make the iac extend all the way and wait the minute, then i would turn the car off and unplug it, and after looking through so many posts i finally found that someone else did that and mentioned it and thats when i remembered to do it before you turn the key off, because i would back the screw off all the way and still be getting 900rpm in park, which is why i asked.
thanks
specialized
Jun 18, 2022 09:26 AM
theshackle
Sep 17, 2020 08:26 AM
camaro71633
Sep 1, 2015 10:24 AM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
