cam opinions needed
Old Dec 21, 2006 | 03:33 PM
MaNiAk86's Avatar
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
cam opinions needed
i am building a 355 non roller motor with brodix aluminum heads(180 cc in runner, 64 cc chamber with 2.02 1.60 valves) will this cam work well? it is a comp cams 260xfi cam.
http://www.jegs.com/webapp/wcs/store...61801_-1_10707
Old Dec 21, 2006 | 05:24 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
looks great to me. what intake combo are you going with?
Old Dec 21, 2006 | 06:07 PM
transbird86's Avatar
Car: 1986 trans am
Engine: 383 hsr
Axle/Gears: 3.70
depending on your intake i would use the 268 xfi p/n 249-12-366-4 at jegs. i have a stealth ram and run that cam it is a great combo
Old Dec 24, 2006 | 10:43 AM
MaNiAk86's Avatar
Car: 1983 trans am
i was going to go with a edelbrock base, as&m runners and ported plenum with 26# injectors and a 58mm throttle body. and everything will be portmatched so it willl alll flow together to create gobs of torque
transbird86: i think that cam is way too big for my tpi intake setup.
- do you think this combo could put me over 300hp at the wheels?
Old Dec 24, 2006 | 12:43 PM
Car: 1986 trans am
Engine: 383 hsr
Axle/Gears: 3.70
it really isn't that big of a cam, i still passed emissions and make good low end torque, if you decide to get a higher stall converter i would definately get the 268 xfi. and yes you should definately be a little over 300 hp at the wheels with alot more torque.
Old Dec 24, 2006 | 10:28 PM
MaNiAk86's Avatar
Car: 1983 trans am
i was planning on running a 2400 stall with a th350 with 3.42's in the rear until i swap it over to a t56.
what is the redline on your motor? i was plannin on shiftin it at only 5500 cause that is where the tpi drops off so a bigger cam wouldnt be worth it.
IROCZ1989
Jan 24, 2016 03:55 PM
camaro71633
Sep 1, 2015 10:24 AM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
