TPI - HELP!
Old Jan 8, 2007 | 10:13 PM
drexton311's Avatar
Car: 1989 T/A
TPI - HELP!
Ok,
I have a 89' T/A 305 TPI...runs good but the tranny is showing its age. Anyway I want to build a small block to put out 400-500hp. I want to keep my TPI set up and my 700R4 (rebuilt of course). I also want to eventually supercharge it...Besides those musts, i am an open book. Should I build a 383 , 355 etc. I really want to keep the cubes as small as possible without reusing the 305 block. This will be a daily driver with the ocassional weekend track dates.... Anyone have any ideas/combos that have worked well in the past. I am still a "shade tree mechanic" so nothing super difficult.
Also - what type of torque converter should I run?
AND does anyone in NE Oklahoma have a good 350 block for sale?
Old Jan 8, 2007 | 10:28 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
If you are going to supercharge it than that is a different ball game. Your cam selection and compression ratio will be different from a naturally asperated car. With the lower compression required for forced induction you most likely will not achieve your goals without the blower.
You can get 400+ horsepower from a 350 naturally asperated with not much problem these days and with TPI using the right parts. With a 383 it is much easier to get 400+ horsepower.
Old Jan 9, 2007 | 08:34 AM
drexton311's Avatar
Car: 1989 T/A
Well to be honest, If I can achieve what i am looking for without the charger then I will persue that avenue!
Old Jan 10, 2007 | 04:03 PM
Car: 1989 GTA
Engine: 369 TPI
You can with no problems. It all starts with a good quality head and some money in your pocket.
Old Jan 10, 2007 | 04:39 PM
dave-92gta's Avatar
Car: 92 trans am/ 93 dodge spirit V6
Engine: L98 V8 - 350
Transmission: TH-700-R4
for the tpi setup, there is alot of choices to make, upgrade the runners, go to a stelth/super ram intake style. baseplate etc. do some reaserch. il mesage you my setup, i have been r ading for about 1 year on my 92 350 tpi and i have a setup for a 450 or so setup NA, but its a 3-4G project
Old Jan 10, 2007 | 04:54 PM
drexton311's Avatar
Car: 1989 T/A
Thanks!! I would definitely appreciate the help!!
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
