Need help choosing a good low end cam
Old Jan 13, 2007 | 05:45 PM
camaro430sut's Avatar
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
Well I searched around am Im not finding what Im looking for. Ive got a SD 305 TPI in my car, five speed and a 3.73 rear end(may go down to 3.42). Anyway im looking for a cam that will give me good low end and a lil bit of mid range. Looking for somethin from like 1500ish up to around 3500 rpm. Im no expert tho so what every you guy can recommend for a good cam it would be very helpful. Theres also going to be a little bit of work done to the stock 081 heads.
Matt
Old Jan 13, 2007 | 05:52 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Matt
The peanut cam, lol
I think you should look for something that makes power in the idle-5,000 rpm range for a TPI 305. This will push the peak torque range of the cam up to where the TPI setup resonates and give a big push in mid-range torque. You are dealing with a low geared vehicle with 3.73 gears. You can trade off some low-end torque for some top end HP and everything will still be great.
Old Jan 13, 2007 | 06:14 PM
See im not good at all this cam selection stuff. It makes sence to give up a lil low end cause of the gears. So what would you recommend for something from idle-5k.
matt
Old Jan 13, 2007 | 06:52 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
The stock LB9 roller cam from 1988 is pretty good in the lows and mids. Smooth idle, etc... Much better than the peanut.
Old Jan 13, 2007 | 08:12 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
The Peanut roller and the B-body LT1/Vortec truck cams are about the best torque producting cams from GM.
Old Jan 13, 2007 | 08:21 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
the cam swap I did for my 305 is in my Sig.
Old Jan 13, 2007 | 08:22 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
My car is getting a LT1 cam this weekend. it has .447 lift, and its the roller cam i needed.
Got it for $20, also have another avaliable.
Sheldon
Old Jan 13, 2007 | 08:39 PM
So what are we talkin as far as the LT1 cam goes. It just so happens I have one of them kickin around. What kinda performance would I be in for. Ill be running 1.6 rockers too.
Matt
customblackbird
Aug 15, 2021 10:16 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
italiano67
Dec 11, 2016 09:21 AM
camaro71633
Sep 1, 2015 10:24 AM
ElPaleterro85
Aug 13, 2015 03:49 PM
