Fuel pomp question 2
Old Jan 14, 2007 | 07:14 AM
Niko the french's Avatar
Car: Camaro'89 TPI
Engine: 305 Ci
Is there a fuse for this pomp ?
Where is it ?
Old Jan 14, 2007 | 07:38 AM
jack harrison's Avatar
Car: 1987 pontiac trans-am
Engine: 350 tpi
Axle/Gears: 3;73 with eaton lsd
there is..., some where! look in the fuse box under the dash on the drivers side. is the pump not working?
Old Jan 14, 2007 | 11:11 AM
Car: Camaro'89 TPI
Engine: 305 Ci
It's not under the dash in my camaro model ( 1989 )
The pump works with a auxiliary battery but not when i turn the key
Do you think it's a Ecm Problem ?
Old Jan 14, 2007 | 11:15 AM
Engine: 350 tpi
depends. do you get a serive engine soon light come up on the dash? there is a relay that you could check. if you get under the car and look up under where the rear axle is there is a relay tucked way up there.
Old Jan 14, 2007 | 11:46 AM
Car: Camaro'89 TPI
Engine: 305 Ci
I have not service engine soon light because it's not possible for me to crack the engine.
And the relay is on the drivers side near the engine and i think it's ok but i don't have command signal.
Old Jan 14, 2007 | 07:53 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
On my 86 the fuel pump fuse is on the passenger fender near the battery.
Old Jan 16, 2007 | 11:49 AM
Car: Camaro'89 TPI
Engine: 305 Ci
Ok thanks.
I test the ecm today and i have not service engine soon light.
Do you think the Ecm is out of order?
Is it possible ?
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
fasteddi
Sep 2, 2015 10:29 AM
redmaroz
Aug 16, 2015 11:40 PM
